Another boiler question, if I may be so bold.
Seem to be a few knowledgable folks on here when it comes to central heating, so though I would ask about my particular problem.
I have a Potterton boiler, nothing fancy, hot water tank etc .
Anyway, for the last few days the boiler keeps powering down. By this I mean that if it fails to ignite then a red light flashes. All you have to do is press reset which restarts the boiler and away you go. There is no ignition as such as it's leccy powered.
There are not set time/circs when the boiler shuts down, some days it lasts all day, other it's 5-6 times an hour. I have tried setting the boiler temp on different settings, but again, there is no set pattern.
Any ideas? Cheers
Any ideas? Cheers
Any ideas? Cheers
Any ideas? Cheers
check the pressure maybe. It wont come on if it's fallen below a certain level, which can happen over time. Check your manual for the correct pressure. Not totally sure so check but think it should be about 1 bar or just over when cold
The original Rouge Trader
Firstly, what Potterton boiler is it youve got?
Could be either the PCB, gas valve, or the ignition stricker plate or incoming gas problem
If its a Potterton Suprima, it will be the PCB, (common prob)
Steve, that's the puppy, it's a Suprima 70. Previous occupiers never left the manual. Erm, what's a PCB mate?
Live long and prosper!!
boilers are a pain in the ass my last one a idel std boiler lasted for 8 years and was still working fine when it was replaced by a bosch combi 28i junior
what a pile of shit was ok for about 2 years then the PCB went then something else then the expansion vessel and since then the pipe from the vessel to the pump has been leaking a bit
its onlt the o ring that needs replacement but i'm not going to fork out anpther Ł180 for those twats to come and fook it up again
need to really know where to get the o ring/seal pack from
Paul
Paul
Try this guy before you go splashing out big money
http://cgi.ebay.co.uk/POTTERTON-SUPRIMA-PCB-1-YEAR-GUARANTEE-CURE-LOCKOUT_W0QQitemZ190276882106QQcmdZViewItemQQptZUK _Home_Garden_Hearing_Cooling_Air?hash=item19027688 2106&_trksid=p3286.c0.m14&_trkparms=72%3A1296|66%3 A2|65%3A12|39%3A1|240%3A1308
But if you do order from them answer this question at bottom of his listing;
Which version PCB is in my Suprima?
407750 type: Has a short square reset button concealed behind the control fascia, to reset you press the 'Grey pad' with the word 'RESET' written on the pad.
See photo on left below.
5102160 type: Has a round black reset button which protrudes through the control panel front, with the word 'Reset' printed underneath, to reset you press this button.
See photo on right below.
Focusv8,
Thanks mate, appreciate that. Spookily enough I have just put this item into my ebay before I came back here, so I sent the chap a question asking if I can collect it instead (save a few quid).
Thanks fella's, hopefully cold mornings will be a thing of the past.
