General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
heat is the only way, but shouldnt takew that long with heat gun etc if your v carefull, the glue residue left behind is the worst but, i use panel wipe which is a painters trade degreaser, also watch incase its been painted b4 and some wassoks masked the sticker and painted around it
1. Use hairdryer to soften the sticker
2. Remove while soft
3. Use brake-cleaner or similar solvent to remove the glue residue
4. Use good polish after to make it look spangly
5. Learn to type in English
I think its '3M' that make a 'wheel' that goes into a drill that is made from a special compound of some sort that will remove the vinyl if heat fails. It's a bit like a 'rubber'.
Of course it's risky and you mustn't let the heat build up too much.
Dont do as my friend did and peel the MG sticker off his maestro with a . . . . ? ?, screwdriver ffs.He was amazed what a kettle full of hot water did.
Eraser wheels, also known as Toffee Wheels due to the smell is what you would be thinking of there Christian. They work well, especially on this sort of thing.
I normally use mine in a 12V DeWalt cordless drill and works fine.
i know them as butterscotch wheels...must be the smell i guess lol
