afr gauge
Er, lean I meant
Here's one of several comparative tests: http://www.modularfords.com/forums/s...1&postcount=84
Yeah, I like mine too just packaged it up to go back for repair, they have had a few issues with them, think they had a bad batch or something look here for more info mate http://forum.aempower.com/forum/index.php
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
I run an AEM ECU as well, so i can use the AEM wideband and capture datalogging etc. through it all - however, i ran the gauge by itself on my old OMEX setup and it was fine mate.
Not 100% accurate as has been said, but its close enough to let you know if there's a problem!
They use the same lambda sensor - i doubt there'll be a huge variation in the interpretation to the display
Either which way - they aren't as accurate as thousands of pounds worth of ECM equipment, but they're enough to give you warning of a problem
Mark RS
12-10-2015 07:01 AM
wheelwizardrefurbs
22-09-2015 06:45 PM
