rear brakes locking(non ford)
Old 02-01-2009 | 01:52 PM
joshF's Avatar
joshF
Default rear brakes locking(non ford)
hello guys
i have a problem with my corsa,when braking my rear wheels seem to lock up and the front dont?
i have had the drums off and had a look and they seem fine cleaned them up and that but still seem to lock up?
i have posted this on another forum and iv been told it could be the load/bias valve?.....but then some say it dont have one its a 1.2 8v corsa
been lowered 60mm all round.
any suggestions on what it could be or if anyone else has had this problem id be grateful for some info
many thanks
Old 02-01-2009 | 02:39 PM
jammerrs's Avatar
jammerrs
if its be lowered 60mm then maybe its changed the geometry of the suspension therefore the amount of tyre on the road would be less?!
Old 02-01-2009 | 02:54 PM
dojj's Avatar
dojj
Resident Wrestling Legend
how tight is the handbrake?
loosen that off a little and see what happens
Old 02-01-2009 | 03:27 PM
RichieST's Avatar
RichieST
May be handbrake, do the wheels spin freely off the ground with the handbrake off? If not i suppose you wouldn't have been able to get the drums off tho...
Did the problems start just after you lowered it?
Old 02-01-2009 | 04:38 PM
joshF's Avatar
joshF
it did it before i lowered it aswell, it also makes a grinding/huming sound when i brake and its coming from the passenger side drum.
it can be pretty bad as in when i brake the car slides....ended up sideways the other day...dont really want to drive it anymore untill its sorted.
Old 02-01-2009 | 06:06 PM
dojj's Avatar
dojj
wheel bearing perhaps?
Old 02-01-2009 | 06:29 PM
joshF's Avatar
joshF
iv checked bearings and also there is no play?
do youn think that air in the system could cause it?
maybe bleed them?
Old 02-01-2009 | 06:33 PM
SiZT's Avatar
SiZT
brake bias valve siezed, made even worse because of how much you lowered it
Old 02-01-2009 | 06:51 PM
900ss's Avatar
900ss
RWD Racer
Hence the car thinks it has 3 fat birds in the back !!
Best bet is to kick the fat fookers out before you all die
Old 02-01-2009 | 07:17 PM
RichieST's Avatar
RichieST
Its what i would have said, but if it doesnt have one then that kinda rules it out!
Old 02-01-2009 | 08:05 PM
900ss's Avatar
900ss
RWD Racer
Screwed into the master cylinder outlets
Old 03-01-2009 | 10:57 AM
It's none of them, vaux's of this age have a very high brake pressure to the rear, if driven "enthusiastically", the drums warp as they are so crap, I replace my drums every year due to this, they will be worse when cold, spin the drum and you will feel tight and loose spots as it touches the shoes.
VERY common problem on vaux's.
The best cure is to rear disc it, as I am doing, when weather permits.
original
30-01-2022 09:20 PM
track.focus'd
12-08-2015 06:53 PM
Red_bull
09-08-2015 09:34 AM
Bosch
04-08-2015 06:14 PM
Quick Reply: rear brakes locking(non ford)
