Symptoms of thermostat failure on 4x4 saff
31-12-2008, 10:50 PM
msd tooned 380+ bhp
removed
31-12-2008, 10:53 PM
poss or maybe h/g starting to fail!take the state out put it in boiling water see if she opens fella
31-12-2008, 11:07 PM
31-12-2008, 11:51 PM
One way to tell if the stat is fooked is to cruise @ 100mph if temp gauge starts to creep up its new stat time
Luciano
01-01-2009, 02:03 AM
01-01-2009, 08:38 AM
Sounds like your stat is jammed shut, may not have been to start with but they cycle from closed/open all the time in use.
01-01-2009, 08:40 AM
Were you getting warm heat inside the car.
01-01-2009, 10:05 AM
msd tooned 380+ bhp
removed
01-01-2009, 10:09 AM
Super Moderator
take the stat out and pop it in the kettle and test it opens and closes
the stat in a 4x4 cossie is unique you CANNOT run the car without a stat
01-01-2009, 10:11 AM
Quote:
Originally Posted by
Tony S Mannock
Why is that tony ?
01-01-2009, 10:14 AM
Super Moderator
Rs500 Registrar
Why is that tony ?
because it has a bi pass cooling system similar to the rs500
01-01-2009, 10:20 AM
Tony S Mannock
So why would no thermo stop you from using the car ?
Im always willing to learn
01-01-2009, 10:24 AM
Actually i have just sat and gave it thought and can see why it isnt a good idea
Paul
01-01-2009, 10:31 AM
Are the coolent pipes rock hard when the engine is running and the coolent cap is on.
Iain Mac
30-09-2015 09:39 PM
The Enigma
29-09-2015 10:31 AM
cossie330
27-09-2015 04:13 PM
