focus rs pistons- zetec block
Ford Freak
just a quick one , im wondering weather i can get away with a set of used focus rs pistons and rods, to use on my zetec turbo project ,
my block isnt new and has done about 80k its a 2l black top block.
im no engine builder, but i would imagine if your engine didnt have any issues with burning oil or excessive crank pressures (symptoms of worn rings/bores) then fitting a different set of pistons, with a new set of rings, would be fine?
Colossal Pervert
You are wrong, they're different bore and completely different blocks inside. Let's put it this way, Ford didn't just bore out the 1.8 to make a 2.0, they re-engineered the block - and that was only for 136ps.. so I don't think boring out the 1.8 by over 4mm is a particularly good idea
ah ok, just checked on Burton Power and youre right, dunno where i got given that impression.
still, i dont see a reason why you wouldnt be able to fit the RS pistons into a n/a engine assuming the FRS and n/a engines are the same internally. id check rod lengths though to make sure you wouldnt need them aswell.
That doesn't answer the question though - £800+vat for a brand new block and rotating assembly capable of handling around 360bhp is pretty good value! (Unless you want more power, of course!)
JK12
33
26-04-2021 12:09 PM
