is this boost normal for the fiesta rs turbo?
29-12-2008, 05:15 PM
right got my boost guage fitted to my fiesta rs turbo, when you put your foot down in 2nd, 3rd, 4th once the boost comes in at 2500 rpm roughly it will stick to around 6psi, when the revvs go above 4500rpm the boost will creap to around 8psi for some reason, is this normal?
the car is totally standard apart from a scorpion exhaust!
29-12-2008, 05:23 PM
boost leak would make it tail off quickly!sounds about right 4 a standard frs to me
29-12-2008, 05:38 PM
Quote:
Originally Posted by
mechanic28
true, i remember when i left the hose off the actuator by mistake and as soon as you put your foot down, boost went everywhere!
thanks mate, i will wait for some more opinions!
29-12-2008, 06:39 PM
up
30-12-2008, 11:11 AM
up
04-01-2009, 09:15 AM
up
04-01-2009, 11:10 AM
Sounds about right, i'm sure the standard boost is 7psi with the boost limit at 9psi
04-01-2009, 11:37 AM
gar mae
10psi mate untill overboost kicks in
04-01-2009, 11:40 AM
i know mines mfi but my comes in at about 3k and holds 10 psi mines standard really no chip,mines the hearts ecu but efi is different ecu setup,wait for more replys mate
04-01-2009, 02:32 PM
paceo
Yup your right, it's been a few years since a owned one
04-01-2009, 02:54 PM
Nothing to worry about...
A standard car wll have a boost limit that will cut off the fuel if to much boost is used.
04-01-2009, 05:49 PM
L8 ECU
but i thought when boost kicks in around 2500rpm isnt the boost meant to be the same up the whole revv range?
paceo
03-02-2016 10:31 AM
carlo
24
05-10-2015 08:20 PM
Matt Baxter
16-09-2015 08:30 PM
knight19770
04-08-2015 12:36 PM
Escortdriver1
31-07-2015 02:36 PM
