alternator power question
my escos has 13.8v on idle if i switch everything on and mean everything rad fans as well, both headed screens...etc... the voltage drops to 11.8 does this mean my alternators hadit underload??
cheers
cheers
you want over 12v really at idle,disconnect your battery and see what the battery is on its own without the alternator or running that wants to be a tad over 12v alone.
sos forgot to mention i did try it at 3000rpm, the belt has its own spring loaded tentioner so it cant be lose... where a cheap place to get a replacement? Camberly Autos?
![007](https://passionford.com/forum/images/smilies/bond.gif)
dont know who's best for yo local mate i'm in glasgow
just shop around, wont be that dear they're very simple alternators
Does the situation ever occur where you have everything on at idle ?
I suspect the answer is NO, there is nothing wrong with this alternator, they cannot do mega loads at idle speed, simple as that, doesn't cause a problem as they don't do it in use anyway.
Do the test at 2000rpm, with a FULLY charged battery and so long as over around 12.2/12.4 stop worrying, is the alternator singing, as they willoften do this when overloaded.
The 90 amp(or whatever) is a peak reading, realistically the peak is a normal continuous max output.
jonfoc
16
11-09-2018 05:35 PM
andrewmctiernan
08-09-2015 03:05 PM
