Brake upgrade for 3dr Cossie??
Folks,
What's the most reasonably priced upgrade for 3dr Cossie brakes, something that works good but won't cost an arm and a leg.
The car in question has front calipers that are seized due to lack of use.
Thanks
Thanks
I got some K-sport 8 pots and 356mm for £700 through apex performance although I am not sure they do cossy fitment might be worth checking out? They are used by several of the time attack competitors.
Thanks for the replies folks.
As for the price I was thinking of paying, something around 500...am I in dreamland?
Is it worth just getting the existing ones re-conditioned?
There are 17" wheels on her, but 16" Esc. Cossie wheels may be fitted in the future.
dont expect anyhing top of the range or new
but 2nd 6 pots do come up at that money
or a set of focus rs calipers or fiat brembo's can be used to make a brake kit up mate
rs focus 324mm disks and std 4wd calipers (with a little fettling) fit under 16" momo alloys with about 5mm clearance between caliper and wheel so may fit under 16" cosworth = CHEAP!
I assume you mean new Fiat discs and pads? In other words will the existing Cossie discs work with the Fiat Brembo calipers?
Thanasis
07-09-2015 07:33 PM
