FAO those with anti lag fitted to their cossies
My Cossie Ate My Money
what is mild anti lag? this has really got me thinking!
does anybody know if i could run mild anti lag on a standard engine, standard 4x4 T3 stage 3 setup?
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Yep, can run it on that spec no problems.
The severity of the anti-lag is all dependent on how much air you can move. The most suitable all round solution is to modify the standard idle valve to allow it to move more air, yet allow it to still function as normal in terms of warm up compensation etc.
After that you're into top hat valves which are definitely more suited to competition cars as the cars lose a lot of their road refinement.
After that - it's big air bypass valve time!
so i could run mild anti lag on the spec im going for with only minor modifications to the engine?
ive been told that anti lag will wreck my turbo and engine but prosumably this isnt the case with mild anti lag?
Rally nut
You would have to fit an EGT gauge to control your exhaust gaz temp. Anyway it will shorten the life of the turbo no matter what. Some people say that with mild antilag you don't make any damage, but I think you should be prepared to pay for a turbo rebuild anyway.
I can get all the pops bangs flames anywhere I want, without anti lag, and without wear to the turbo, as set one of the maps to very low rev limiter, with hard and soft further apart, works really well, but works so much better after drilling a 5mm hole in the front pipe, after the lambda sensor!!
Happily retired
Came with the SM4 ecu, but I asked Mark what it did, makes lots of noise that appeals to some people, no performance gains. Hence I dont have it connected, I have more than enough noise & flames already. .
I have this feature on my dta s60 pro, I am not running an idle valve.
But we are setting up an air bypass valve for the als,is there any
other iscv I could use apart from the ford/weber marelli one ?
puddy
puddy
This is my mates cossie being mapped with his anti lag on - he's got it switchable & only really uses it for track days, he says its the best thing he's done on the car!
http://uk.youtube.com/watch?v=7dFcMA9AKTI
Need to make sure everythings heat wrapped, turbo & downpipe etc - everything gets bloody hot & melts/falls apart if you dont.
Sponsor
is it the one they use in the ford bypass set up ?
sorry ,so many questions!
puddy
I remember the famous EA rollers mine did 328.8BHP, butb as this was EA BHP the real figure was 271.7bhp, with 10.5 AFR!!
So it made less power than my stage1 GGR chip, but used 10 psi more with 1/2 the mpg!!
My bang bang is better than that, loads more flames and noise, and it's only the limiter set at 3500, drilling a small 5 mm hole in front pipe after lambda helps!!
Probably true - the jobsworths at Bedford black flag you for farting, not been black flagged so far but mainly been used at the ring and at non msv trackdays which dont have noise tests.
You only got yours for 'flames & noise' then?
Colossal Pervert
They're still in business, partly, because people such as yourself are blinded by their incompetence. I put a standard 115ps car on their rollers and it reported 148bhp!!
Your a proper keyboard warrior arent you. Not my car is it mate - as I said, its my MATES CAR.
I've never taken 1 of my own cars to EA personally, this thread isnt about their fucking rollers anyway or whose taken what car their and swung their cock about its about anti-lag & I was just showing my mates cossie which has it fitted (which wasnt done by EA).
