engine lightening and balancing ,
ok peeps ,
looking at getting my new cossie bottom end lightned and balanced ,
now i kinda have a vauge idea of whats invloved ,
but how exactly to they balance the parts ?
i know they need the full rotating mass of the bottom end , i.e crank rods pistons , flywheel , clutch cover ,pulley ,
do they need bearings ?
also does anyone know any companies in the north east of england that can do this ,
just trying to get an idea of how much it costs,
i reckon its got to be benafical to revving and stress on the engine ,
any inputs folks ,
beef
any inputs folks ,
beef
teeside motor factors done mine cost 117.5 including the dreaded few years back
Pistons as said are weighted for lightest one, rods balanced end to end, then as a set, crank, pulley, clutch diaphragm, flywheel, basically anything that rotates directly from crank.
Lightening can work wonders on cossies as the flywheel is large enough and heavy enough for the QE2!!, it will accelerate so much better with a lighter flywheel.
I have every engine done, even had the odd one frozen(not popular here in uk) it really does make a difference that you will feel and notice, depending on how bad it was to start with, balance wise cossies are not great in std factory form.
If only doing 1 job though it would have to be flywheel lightening for bang per buck.
It will rev a lot easier feel more eager and be smoother when all done properly.
Personally for the cost I would mod the std one by lightening, bearing in mind the weight is there for a reason to start with, that of a smooth engine, though to be honest I have never really noticed any lumpiness, but you can feel the need for just a few hndred more revs when pulling away quickly as there is less flywheel inertia effect, other than that no downsides.
I would say lightening would cost around Ł45, and think the std flywheel is around 10 lbs, these can certainly be taken to 6/7 lbs.
It may not sound a lot but the point is it is not having to be accelerated, so will have a much larger effect than you'd imagine.
According to th ebloke in Burton when my brotehr went in there is no point at all in lightening and balancing the bottom end as it can't rev and will run crap. Funny, mine's been done and doesn't have either of those issues
beefy speak to amac engineering in northallerton, propper old school machine shop, they built the engine in my anglia this year..
http://www.amacengineering.co.uk/
steve
steve
did you have you bottme end balanced ste ,
i take it you recommend them then fella,
deffo going to have this done me thinks ,
just need to buy the rest of me parts ,
quick question , is an alloy flywheel really nessacary or will i standard lightend one be just as adequate ?
thanks lads
beef
thanks lads
beef
amac engineering as said or parkside engineering malton have used them both,both excellent service, wouldnt use teeside motorfactors cowboys!!
YB flywhel is actually closer to 10 kg.
Lightening stock cast flywheels can be dangerous you are far better off buying a purposely designed lightweight billet flywheel like this.
beef, my bottom end was already lightened and balanced, it was checked and found to be spot on.
yes I do recommend them, my engine is the quietest pinto I have ever heard running bar the induction noise that you get with twin 48's lol
steve
steve
ive had a few rst blocks machined and cranks polished,carnt remember what they charged me to lighten and balance my last s1 engine wasnt a lot,im suprised tmf are still going they havernt got a clue
na mate bigest mistake i made sold it just bought a D PLATE NON CUSTOM S1 just found out its the only d plate non custom that was made so restoring it very soon then it will be for sale want a escort cos next
yeh wish id kept that 1, hopefully starting s1 very soon full inside n out paint job with all gen ford panels yours be ready for next summer??
trying to mate ,
you know how it is , all boils down to money lol ,
but the shells of for media blasting in the nxt few weeks , got all the new panels needed which is just two new gen wings and front panel , and there only getting done so i know its 100%,
got my cossie engine and running gear , just starting on stripping the parts ready to be painted etc , havent fully decided on colour for the old girl,
ohh and got my s1 kit , just need coilovers new brakes , and karl to fabricate the lateral link style rear end
going to have a big push at it , but you may see it as a work in progress at a few shows as part of jackos stand for blue oval ,
resto thread begins midweek , as my shell comes to my new garage
beef
beef
Marc sierra
12
30-08-2015 10:38 AM
