What parts would u use to build a genuine400 bhp yb engine
If it were me, I'd over-spec much of the job (pistons, rods, bearings, bolts etc) as you never know if the bug will get you and you'll want more. If it doesn't, you're left with a reliable motor.
T38 should be up to the job - there's a clown on here who says his is pushing 550! ha ha ha!
400 should be fine.
JK
400 should be fine.
JK
Ever checked out Craig Rainers MkII Escy racer with a yb turbo in? 420Bhp, 400 ft/lbs torque from 2500rpm to 7k and its ALL STANDARD internally!!! Its got a hybrid turbo and a Motec ecu. It was built by Jon Edwards at JEMS. Check out www.jemsracing.co.uk
Have got a t34 with 360 bearing allready on car but i thought they run on;y up to bout 360 bhp, Was thinking of going for standard rods, b 12 inlet, standard exhaust cam , siemens 63lb injectors , mahle low comp pistons, and have the thing lightened and balanced and with the t38 turbo, What sort of power would u expect from that speck
Live long and prosper!!
One of MAD cars has made over 440 bhp on a std head
T34/63 (depending on spec can see around 420 max)
All depends what u really want ie 400 now 500 later??
My advice is spec for 500 (bottom end) and aleast it won't cost u another set of piston etc cheaper to that way imo
Paul
Paul
B1mbo
well not sure on siemens injectors as i dont have any knowledge on them but dependand on what spec t38 you could see up to 440+ bhp but you would need some work on your head
also youd want to use a decent gasket id say a wrc gasket is the best bet
Paul
B1mbo
Paul
Paul
DANISH cosworth abuser
best bet and J1mbo will agree go for a tried and tested spec from a known tuner as they have many different combos that will give different results.
its not just about power a good torqure figure is also the key
Decide on a tuner and take their advice
Paul
Happily retired
Before you start trying to tell Mark how to design a Cosworth engine can I suggest that you go away for about 30 years become twice as good as your old man & then you will be almost at the same level of expertise as Mark on the subject.
oh dear not again
Why can't people get on ??? its only an internet forum to ask questions and express views and opinions
Jim no doubt knows a lot more than most people(lucky for him!!)due to his dad
Rod i would have expected more form you i'm dissapointed
This is not a competition guys
Paul
Paul
B1mbo
oh dear not again
Paul
Paul
i dont thinki deserved that was abit out of order ! i didnt "tell" mark to do anything ! i was having a discussion about things ! not "teaching him how to design a yb"
and rod why come on and make such a bold statement then not bother to back your comment when i replied ? ? ? ?
and paul i wouldnt say i no more than you ... i still have alot to learn and its good when im corrected !
Football Cwazy
Jimbo, your first reply shows you don't know as much as you probably think...and i'm no expert myself!
On the other hand at least you replied lol
No need for Rods below the belt comments either, but we've come to expect that from him as he's like that and loves getting people to bite.....his car bores the fuck out of me now and luckily it's never working long enough for me to be bothered.
My own take on it is that if you want a nice fast reliable road car then get a T34 on a standard engine and head...maybe with a little porting. It won't make 400bhp but it'll still be much nicer to drive than a 420bhp T38 powered car ( although not quite as quick once past 70mph. )
Even better would be a small GT30 as mentioned above!
B1mbo
My own take on it is that if you want a nice fast reliable road car then get a T34 on a standard engine and head...maybe with a little porting. It won't make 400bhp it'll still be much nicer to drive than a 420bhp T38 powered car ( although not quite as quick once past 70mph. )
i would rather read peoples comments and learn from them ...
can i ask why you dissagree with it too
*** Sierra RS Custard ***
Personally I think Jim gave some pretty good advice in this thread, there is more than 1 way to skin a cat, and while MAD and SCS might have different ways of doing things both of them are perfectly capable of building a good 400bhp or 500bhp engine, there is no right or wrong answer IMHO
Football Cwazy
Fair play for actually wanting to read comments and learn!
there are only a few peoples opinions on here that i personally would trust though, there are LOADS of clever people too, but only a certain few who i'd actually trust to work on my own cars and believe what they tell me as fact...they are;
Karl Norris
Stu
Mark Shead ( as long as his runt is nowhere to be seen )
Tony Turbosystems
As for what i disagree with, the first part about comp ratio...there's really no need to worry about it at those power levels.
Your other comments are kinda right, although it depends what parts are fitted to get a standard head to make 400bhp...i've personally never seen a T34 do it anyway.
Don't take my ramblings as fact though whatever you do!
Karl Norris
Stu
Tony Turbosystems
C.R.E.A.M.
Toluene can be used as an octane booster in gasoline fuels used in internal combustion engines. Toluene at 86% by volume fueled all the turbo Formula 1 teams in the 1980s, first pioneered by the Honda team. The remaining 14% was a "filler" of n-heptane, to reduce the octane to meet Formula 1 fuel restrictions. Toluene at 100% can be used as a fuel for both two-stroke and four-stroke engines; however, due to the density of the fuel and other factors, the fuel does not vaporize easily unless preheated to 70 degrees celsius (Honda accomplished this in their Formula 1 cars by routing the fuel lines through the muffler system to heat the fuel). Toluene also poses similar problems as alcohol fuels, as it eats through standard rubber fuel lines and has no lubricating properties as standard gasoline does, which can break down fuel pumps and cause upper cylinder bore wear.
Toluene has also been used as a coolant for its good heat transfer capabilities in sodium cold traps used in nuclear reactor system loops.
Toluene has been abused by teenagers in the early to mid 1990's to get high, this was prominent in Dallas, Texas. This was known as "Tolly" in the streets, in which certain brands of octane booster that contained Toluene were used in small rags and "huffed". The effects caused mild to serious hallucinations
For example, ask Karl and Mark what compression you should run for 600bhp, and you will get two VERY different answers.
B1mbo
Karl Norris
Stu
Tony Turbosystems
Karl Norris
Stu
Tony Turbosystems
where scs have specific chips for set engine specs if someone wanted to use a scs chip they would build it to that spec !
same as for msd mad reyland ect ect
Football Cwazy
Chip, you really are a cock sucking fag at times!!
They may disagree on things but i'm pretty sure all can build a 600bhp engine just fine...so it doesn't matter in the slightest who i listen to.
The poster asks for advice on what parts to build a 400bhp engine he'd need, it'd be very poor advice IMO to recommend using a chip/mapper that requires a change in compression ratio at such moderate power levels, no?
His dad may have built lots of T34 engines that make 400bhp...but i'd personally be surprised if any were on standard head/cams. And if they were then i'd suspect turbo's would be very stressed, even ones with cut back turbines!
And please don't pick apart this post and quote each little sentence seperately, as;
1) You bore the fuck out of me.
2) it's not getting the questions answered and is unfair on the guy asking questions!
Football Cwazy
the reason i said about different comp rations is not due to "safety" or stregnth reasons its due to the different chips different tuners use ...
B1mbo
if your using a company that will/can live map then build the engine as you like and get it live mapped !
but not everyone wants to use the same company !
For pointing out you were having a go at someone for no reason, wow, interesting viewpoint.
Well if you believe Karl when he says build it low comp is the BEST way and you believe Mark when he says build it high comp is the BEST way, what decision would you then make on your own engine?
I personally wouldnt specifically change the compression at that power level, but on the other hand if you are rebuilding it anyway (which IS a good idea if you want it to last) then lower Comp is a perfectly acceptable way to go, not the choice I would make myself but still acceptable.
Im sure Mike R or J1mbo can give you some details of that.
Cossie Rich's T34 on a low comp engine did 17000 hard miles before it finally died, at 2.3 bar IIRC
Actually it IS getting the question answered, as its getting across the fact that you are wrong to keep saying things cant be done the way j1mbo is saying, when the fact is they CAN
Ive no interest at all in if I am boring you or not, my interest is just in the poster getting good advice.
