T34 experts........help please!
Old Nov 17, 2008 | 11:46 AM
evo200's Avatar
evo200
Default T34 experts........help please!
For any of you guys with a T34/0.48.......
What rpm is the boost threshold generally and when does it run out of puff? How do you find it for driveability?
I'm on a T34/0.63 at the moment and it doesn't start pulling 'till about 3200rpm the engine is only 7.5:1 CR and feels too sluggish low down (could that be mapped out with more ignition?)
Was hard work keeping up with an ST170 on twisty roads no long ago!
So I'm thinking of going down a housing size.....
803's
RS200 spec intercooler
std head + cams
3" exhaust
1.5 bar held
Old Nov 17, 2008 | 12:11 PM
charlie luciano's Avatar
charlie luciano
No too sure about the rev range info but I have a 34 with a .48 housing, it does spin up quickly and is not laggy, where as .63 .55 you have to wait a bit for the boost
Luciano
Old Nov 17, 2008 | 12:28 PM
Andreas's Avatar
Andreas
Im no expert but I looked through my pectel datalogs and found one where I boot it in 4th gear at 2500rpm.
By 3200rpm it got full boost ie 1,6bar.
It then hold this and actually creeps a bit higher to around 1,7bar and it isnt until around 5500rpm that it starts to tail off very, very slowly. By 6400rpm it still holds 1,6 bar.
Old Nov 17, 2008 | 12:45 PM
evo200's Avatar
evo200
Thanks guys, that sound ideal, I dont generally take the engine past 6000rpm. What injectors are you using?
pete
Old Nov 17, 2008 | 05:26 PM
Andreas's Avatar
Andreas
Its a standard compression engine using 803's but im switching to bigger siemens injectors for next season. I don't like to rev it either so for me its ideal.
But you better ask for some more opinions as I don't know much at all.
Old Nov 17, 2008 | 07:01 PM
I have full boost by 2700, all held very well at 1.9 bar till about 6500, near it's 7300 soft cut.
Mapping will make a world of difference, especially off boost, mine doesn't feel as quick but that is because it has no sudden increase, as there is not so much lost power low down now, as it has more so not such a step, onto full boost.
Mine is on greys and std cams but modded head, only light modding on exhaust ports.
I noticed when it was mapped, it has loads more advance now.
Old Nov 17, 2008 | 07:18 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
mine made 36psi at 2700, they do run out of puff at the top though
Old Nov 17, 2008 | 08:18 PM
evo200's Avatar
evo200
Ta guys,
What approx power are you likely to get using the 0.48 ?
Tabetha, do you run the greys with the pintle caps off? I remember reading somewhere that its preferable to do so.
Does anyone know if the 0.48 housing a straight swap in place of the 0.63 or is there some engineering involved?
cheers
pete
Old Nov 17, 2008 | 09:34 PM
JTECH James
Passion for Fords!
straight swap.
370-380 is absolutly flat out, and turbos become knackered at about 30k miles before they need rebuilding at that.
and the exhaust housings crack due to the constant heat battering
Old Nov 17, 2008 | 09:39 PM
mechanic28's Avatar
mechanic28
Originally Posted by JTECHSAFF
straight swap.
harsh sig so a .55 should be able to push 380-385 with out stressing it out to the max?
Old Nov 17, 2008 | 09:40 PM
JTECH James
Passion for Fords!
maybe....ive never tryed a.55
Old Nov 17, 2008 | 09:44 PM
mechanic28's Avatar
mechanic28
never tried a .55! you aint lived until you have!
Smit's Avatar
Smit
The 60ft Launch King
I have a .48 T34
hit boost by 2300 and full chat (1.6 BAR) @ 3100prm
have a slightly ported head and 7.8:1 pistons.
Drives very well and doesn't run out of puff over 5k like a T3 but you won't have the lag of a .63
Old Nov 17, 2008 | 10:23 PM
westus1's Avatar
westus1
if you dont rev the tits off it or track it then the smaller .48 will make the car much nicer to drive daily
Old Nov 18, 2008 | 08:04 AM
I have tried with the caps on and off, I didn't find any difference, but will put it on the rollers again to check, also going to check airbox versus cone/cone with shield.
T34.48 will do more than 380 without problems, CR turbo's man used to run this on his 2wd cossie, but lightly ported head, works wonders on these particularly at top end, where as said they don't tend to run out of puff so easy.
I am going to a T34, with a .60 ar comp housing as I have std T3 comp at the mo machined out to take t34 trim, so it has an easier time.
Old Nov 18, 2008 | 08:15 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Tab,
am very interested in the cone v air box test. Make sure you post the results bud
Old Nov 18, 2008 | 08:19 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Before you do ANYTHING, take it to Martin Hadland and have the map checked over. Recently he has managed to get 30-40bhp AT THE WHEELS by optimising the "off the shelf maps"!
Once you have done that, you can then try the car in it's new format and see if you still find it wanting .
You may find that the injectors are running out of duty cycle, but a switch to greys would give 320bhp at the wheels with the spec you have .
Old Nov 18, 2008 | 08:22 AM
Mike Rainbird
Caraholic
pete
No wonder you're loosing out to ST170s then . You should be revving to 6500 in EVERY gear.
Old Nov 18, 2008 | 08:24 AM
Mike Rainbird
Caraholic
Do NOT use the greys with the caps ON and high boost, or it WILL melt .
Old Nov 18, 2008 | 08:29 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
803's
std head + cams
3" exhaust
1.5 bar held
It should start pulling way before that!!
Btw.. What ECU is it running?
Old Nov 18, 2008 | 08:50 AM
Oddly enough this is why it is done on the rollers so it can be checked.
Old Nov 18, 2008 | 10:01 AM
evo200's Avatar
evo200
Its probably a combination of me being a shit driver and the crappy ratios in the renault transaxle!
Its on an L8 ecu Martin, I think its an A1 rallysport chip in there. It was like that when I got the car.
It will make +ve boost (approx 0.5 bar) below 3k rpm but doesnt really get going till about 3200rpm
Another thing I notice is it seems to pull better on half throttle than full throttle when on boost
Old Nov 18, 2008 | 10:05 AM
Martin-Hadland
Do you know the chip is correct for your engine spec? I would suggest going for Siemens injectors and a remap, I can do this on our DD rolling road for you and would provide a print out of before and after.
Old Nov 18, 2008 | 11:09 AM
Mike Rainbird
Caraholic
You may find that your generic off the shelf chip is basically shit for your engine .
Old Nov 18, 2008 | 12:28 PM
evo200's Avatar
evo200
Yep, I agree
Whats better about the siemens injectors compared to 400's or 403's ?
Was thinking about going closed loop and wasted spark while I was at it.
Old Nov 18, 2008 | 12:40 PM
Mike Rainbird
Caraholic
Yep, I agree
Just the fact that their higher flower gives you scope to increase the power at a later date, with one less thing to have to change - as in, they have a much greater ceiling of power.
400s around 400bhp LIMIT
403s around 450bhp LIMIT
Siemens blacks around 500bhp IIRC
Old Nov 18, 2008 | 12:51 PM
evo200's Avatar
evo200
So to dispel any myths, its nothing to do with a better spray pattern/ fuel atomisation etc then, as long as the car is mapped correctly for whatever injectors are being used?
thanks
pete
Old Nov 18, 2008 | 01:04 PM
Mike Rainbird
Caraholic
thanks
pete
Correct, although the Bosch 400s do have a nicer shaped spray pattern than the 403s . However, careful mapping will get the best out of all injectors .
Old Nov 18, 2008 | 01:08 PM
evo200's Avatar
evo200
Always wondered if that was the case.
Ta Mike
Old Nov 18, 2008 | 04:54 PM
Some people have had problems with emissions on Siemens, and have gone back to greys etc to get the car through the mot.
Old Nov 18, 2008 | 05:06 PM
JTECH James
Passion for Fords!
and some havent.....greys are fine for pony power lol
ive never seen a .48 make more than 380, i had a good spec motor on a .48, we made lots of mods during it life to try and gain, and gain, and come the end i could have welded the wastegate shut as i was using every ounce of air it could produce. they simply make power to low, and ultimately dont flow enough air to make more. The compressor map and simple physics tell you that.
i even had surge at 36psi, which was the restrictive neck on the plenum, so ran a swedish to overcome it.
unless its tdi rollers
and they do become "consumable" items running 2.5 bar, as i found out several times. one of those being from cr turbos.
im sure they would last longer if you drove like a fanny though
Old Nov 18, 2008 | 05:08 PM
hitchwest's Avatar
hitchwest
im on t34 .48 with a norris gunship been good but just bought some greys and will be going back to karl yo get him to work his majic again
only problem i have with it is that sat at 80 its spooling up so seems to use a bit of juice on runs weather bigger housing would change this i dont know
Old Nov 18, 2008 | 05:24 PM
JTECH James
Passion for Fords!
yes it would....
i can cruise in closed loop at 110mph with the T4....
Old Nov 18, 2008 | 08:19 PM
evo200's Avatar
evo200
We just need someone to manufacture a reliable VATN turbo for petrol engines then we'd all be sorted!
I don't think theres many new 911 turbo ones kicking about though!
Old Nov 18, 2008 | 08:50 PM
chriswoodleyrst's Avatar
chriswoodleyrst
What u mean by using grays with the cap on will cause it to
melt
Old Nov 19, 2008 | 08:19 AM
Mike Rainbird
Caraholic
melt
Which part of the statement did you not understand ? (however, please note I did qualify the above by stating that if you are running lots of boost - on a T34 0.63 - as in pushing the turbo it it's physical limits)
Old Nov 19, 2008 | 02:37 PM
cozmeister's Avatar
cozmeister
More boost Igor!
melt
Presumably because they're will be more air than fuel, which = lean = heat = melted engine.
Old Nov 20, 2008 | 08:01 AM
In which case it would be noted on emissions, so you'd be fairly silly to run it like this as you would know the likely outcome beforehand.
I don't know how much bosch know about injectors though.
Old Nov 20, 2008 | 08:20 AM
Mike Rainbird
Caraholic
They know "quite a bit" , but can't be there looking over the owner's shoulder to make sure they are using the correct rated injector for the specific application .
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
28
Sep 8, 2015 07:10 PM
