Flocking
Old Nov 15, 2008 | 10:48 AM
Billy_RS's Avatar
Billy_RS
Default Flocking
Just had a dash, centre consol and door cards flocked by a certain flocking company.
Poor service, poor effort, poor time scale.
Just wanted to know if anyone else has had similar problems.
Old Nov 15, 2008 | 11:53 AM
Who was the company ,text me if you dont want to post it,had all mine done at central blast great job and done within a week
Old Nov 15, 2008 | 11:54 AM
Ryan's Avatar
Ryan
seems stupid to post about it if your not going to name the company, i.e to help other aviod them same scenerio.
Old Nov 15, 2008 | 12:25 PM
Billy_RS's Avatar
Billy_RS
I'm not going to name the company.
Just for the record it was not dan @ rapid ford or central blast.
Old Nov 15, 2008 | 12:28 PM
Billy_RS's Avatar
Billy_RS
I'm not going to name the company. Just for the record it was not dan @ rapid ford or central blast.
Old Nov 15, 2008 | 12:29 PM
J1mbo's Avatar
J1mbo
B1mbo
whats the point of this post ?
your question is "Just wanted to know if anyone else has had similar problems"
how is anyone supposed to awnser if they dont no the company !!
Old Nov 15, 2008 | 03:22 PM
Kelv's Avatar
Kelv
Almost there!
Pointless post really
Old Nov 15, 2008 | 04:16 PM
Garage19's Avatar
Garage19
Why not name the company? Tars other flocking companies for no reason.
Old Nov 15, 2008 | 04:50 PM
doctor stavros's Avatar
doctor stavros
AMG C32
nice pun
Old Nov 15, 2008 | 05:33 PM
Billy_RS's Avatar
Billy_RS
Its not pointless at all.
I wanted to know if anyone else had problems with flocking company's.
Why does everyone on this site always roll their eyes like they know all and put Gaylord reply's up like 'pointless post'?
If somebody had a problem with abc flocking services and that was the company i used, then id know that it wasn't just me who had the same shabby treatment.
Old Nov 15, 2008 | 05:35 PM
Billy_RS's Avatar
Billy_RS
I don't want to come on here naming and shaming incase it wasnt the fault of the company... IE illness etc...
Old Nov 15, 2008 | 05:55 PM
Ryan's Avatar
Ryan
then why post
Old Nov 15, 2008 | 06:00 PM
Rossco's Avatar
Rossco
Oh Ryan your such a "Gaylord"
Old Nov 15, 2008 | 06:03 PM
J1mbo's Avatar
J1mbo
B1mbo
Old Nov 15, 2008 | 06:13 PM
Ryan's Avatar
Ryan
shut it you pair of hom's!
Old Nov 15, 2008 | 06:16 PM
J1mbo's Avatar
J1mbo
B1mbo
okii hunny
studabear's Avatar
studabear
cant believe i've just wasted a minute of my life reading this pointless toss
Old Nov 15, 2008 | 06:44 PM
Garage19's Avatar
Garage19
As you have stated flocking services, are you implying it was Suffolk Flocking Services?
Old Nov 15, 2008 | 07:04 PM
Ryan's Avatar
Ryan
somebody is going to have some problem with some company at some point.
I had a problem with a company once.
That is all.
Old Nov 15, 2008 | 08:33 PM
Kelv's Avatar
Kelv
Almost there!
oh Ryan you Gaylord, thats a pointless response
Old Nov 15, 2008 | 08:47 PM
J1mbo's Avatar
J1mbo
B1mbo
pmsl at you 2
Old Nov 16, 2008 | 12:30 AM
Billy_RS's Avatar
Billy_RS
wasteman reply's as usual.
It was suffolk flocking services. Will never use again.
Old Nov 16, 2008 | 12:32 AM
Billy_RS's Avatar
Billy_RS
wasteman reply's as usual. It was suffolk flocking services. Will never use again.
Old Nov 16, 2008 | 08:00 AM
Garage19's Avatar
Garage19
I can only asume you were the chap with the 206 dash?
I wouldn't normally comment about a customer on a public forum but seeing as you have no problem in making comments about my company i feel i need to reply.
There were a number of issues with your order.
Issue 1
When we spoke the first time you asked if I could coat your door cards. I said yes, as long as they were not made from/trimmed in a porous material like fabric. You assured me they were plastic.
When the door cards arrived they were indeed plastic but according to your note it was not the plastic sections you wanted coating. It stated it was the material trimmed inlays that you wanted coating. The glove box lid was also trimmed in material.
I had made it very clear the first time we spoke that this was not possible. I rang you again immediately to explain again what porous meant and why I had made it clear to you previously that I could not coat material on the door cards or the glove box.
From previous knowledge I knew there would most likely be fibre board under the material on the door cards so offered to remove the material inlays, (drilling out lots of plastic rivets) prep the glue covered rough fibre board into a smooth surface more suitable for flocking (lots of sanding, several coats of filler primer) and then bond the door cards all back together after flocking.
I told you I couldn’t do the glove box as it had padding under the material.
I told you this would add Ł50 to the bill.
You said you would think about it and then shortly rang back saying a friend had recommended the same way forward and you would like to go ahead.
Issue 2
I offer free return carriage on all my dashes.
When your dash arrived the DHL man was having trouble lifting it. He explained it had been put in the back of his van on a pallet. The parcel was huge and weighed a ton.
On un wrapping the dash I discovered that you had included most of the car with it. There were big bits of structural metal work that should have stayed on the car, half the wiring loom and would you believe it, even the steering column!
Due to this the dash wouldn’t fit inside my enclosed heated drying racks which in turn meant it had to be air dried. (3 days rather than 24hrs).
When all the bits were coated they were packed up into three parcels. Door cards, hand brake surround and lots of other parts and finally the dash it’s self.
The first two parcels were sent out by my courier with no problem and you received them. I received a call from my couriers saying that the third parcel was way over their max parcel weight (I send a lot of dashes, never happened before) and that they wanted an extortionate amount of money to send it.
I picked the dash parcel back up and set about finding a more reasonable carrier for a parcel of this weight/size. I came across Parcel 2 Go and booked a pickup. They didn’t arrive. At this point (one week after receipt of dash) you rang checking on whereabouts of the dash I guess as you received the other parts without the dash.
I informed you about the problem with the courier / parcel weight and said I had booked another pickup for that day.
Again they did not arrive to pick up. I phoned you the very next morning to say I was going to drop at original courier, pay the extortionate amount and apologised for the delay. You put the phone down on me.
A week later you rang and asked why I hadn’t coated the glove box. I went over our old conversation about porous materials again and you put the phone down on me again.
In my opinion I did my best to try and honour my free return carriage on something that was totally unreasonable and I worked around the problems that you had sent me. You were rude, ill mannered and ignorant to everything I explained to you clearly from day one. I should have just sent the whole lot back from the start, un-coated and at the very expensive rate with an invoice for the carriage rather than try to help.
Old Nov 16, 2008 | 08:04 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Old Nov 16, 2008 | 08:34 AM
bennyboy020's Avatar
bennyboy020
Dont think theres an reply to that,
well worded mate
Old Nov 16, 2008 | 08:50 AM
gil's Avatar
gil
id have climed up my own ass and died after that response
Old Nov 16, 2008 | 09:03 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Billy x infinity
Old Nov 16, 2008 | 09:14 AM
J1mbo's Avatar
J1mbo
B1mbo
whos the gaylord now pmsl
Old Nov 16, 2008 | 09:15 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
It seems common at the mo to be bad mouthing the traders on here only to be shot down when the truth is told, then all goes quiet
Steve
Old Nov 16, 2008 | 09:58 AM
Miller 3's Avatar
Miller 3
Well put Doug On a lighter note you coming to the next roller skating meet
Old Nov 16, 2008 | 10:28 AM
Kelv's Avatar
Kelv
Almost there!
is it still Ryan?
Old Nov 16, 2008 | 10:33 AM
Kelv's Avatar
Kelv
Almost there!
Doug (Garage 19) lets now hope that this guy is the customer with the 206 and not someone else.
Old Nov 16, 2008 | 10:42 AM
ballbag42's Avatar
ballbag42
what a reply i would be highly embaressed naming someone without putting all the facts down for all to judge and make a sensible decision oooooops
Old Nov 16, 2008 | 11:04 AM
Billy_RS's Avatar
Billy_RS
Ok.
1. When we spoke on the phone, you said it could all be done in a few days/week.
It in fact took just over a month.
2. During that month, id tried ringing you 30+ times with no answer.
3. I fully understand the meaning of porous.
But when your told it will be flocked or at least attempted and turns up (finally) not even tried?
4. The dash has had a clip on the back broken.
5. There was a screw type clip missing.
6. The finish is good in most areas, but looks poor in others.
7. I wouldn't of even come on here and said anything, but you've put the project back over a month. Pissed me off never answering the phone, and how can it take so long to be delivered back? LONG!
Also i've noticed that the same old passionford bum boy brigade jumping on the bandwagon.
"Owned!"
"Nicely worded"
Don't start sucking each other off quite yet, you aint heard the full story up to now.
Old Nov 16, 2008 | 11:22 AM
Rossco's Avatar
Rossco
Old Nov 16, 2008 | 11:27 AM
bennyboy020
GAYLORD
Old Nov 16, 2008 | 11:39 AM
Kelv's Avatar
Kelv
Almost there!
Well, i dont know Doug from Adam, ive never met him and probably never will.
but if your going to put something on an open forum then you have to be prepared for people to express there own opinion - after all thats what you wanted in the first place!!
Old Nov 16, 2008 | 11:46 AM
gil's Avatar
gil
Ok.
"Owned!"
"Nicely worded"
im not part of the bum boy brigade... but wouldnt mind joining up... i take it your a founding member
