Brake bleeding/fluid problems...
Old Nov 14, 2008 | 08:26 PM
Lee Reynolds's Avatar
Lee Reynolds
Default Brake bleeding/fluid problems...
Fitted all my lines up today and put the fluid in the res....bearing in mind ive done thise before and had no problems i just expected to open a bleed valve on one caliper, press the pedal and get some fluid through....i was wrong. I cant get any fluid through any pipe.....no fluid is even coming out of where the brake pipes fix into the master cylinder. There are no blockages ive pulled the res off and i can see through the holes and see the rod moving freely...
Any ideas?
Old Nov 14, 2008 | 08:29 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Try a pressure bleeder.
Old Nov 14, 2008 | 08:36 PM
Lee Reynolds
But if the pedal is pumping NO fluid AT ALL through at the moment doesnt that give signs of a problem? What about if i bled it with a pressure one.....the pedal still wouldnt be pumping any fluid??? Or is it a matter of 'getting it going' sort of thing? Like i say i did this on my s2 when i removed the ABS and had no issues!
Old Nov 14, 2008 | 08:41 PM
Dangerous Malcolm..
For the sake of Ł15-Ł20 I'd try the pressure bleeder and go from there.
Old Nov 14, 2008 | 08:49 PM
kellyalfie's Avatar
kellyalfie
lee go back to s1
Old Nov 15, 2008 | 10:04 AM
NUTS RuS's Avatar
NUTS RuS
open all bleed valves
Old Nov 15, 2008 | 04:17 PM
Lee Reynolds
Tony fuller said that too Nuts so ill have a go cheers
Old Nov 15, 2008 | 05:35 PM
Lee Reynolds
FULL POINTS to nuts and Mr Fuller cheers
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
