t35 trouble
Old 11-11-2008 | 08:02 PM
p100sr500's Avatar
p100sr500
Default t35 trouble
anyone got any ideas , just fitted a t35 to my 3dr and its sorted lots of probs but, it boosts to 18psi then drops off to around 12 whats the verdict is it !!!ked
Old 11-11-2008 | 08:22 PM
montecos400's Avatar
montecos400
Have you tried a different actuator.
Old 11-11-2008 | 08:28 PM
LHD220Turbo's Avatar
LHD220Turbo
all turbos will reach a boost spike and then tail off
give us a bit more info; where in the rev range does it drop off; whats the spec of the engine?
Old 11-11-2008 | 08:29 PM
p100sr500's Avatar
p100sr500
chs m8 will have a play 2moz if the neighbours can stand it
Old 11-11-2008 | 08:32 PM
p100sr500's Avatar
p100sr500
engine spec is escort small turbo 4x4 with 2wd sump and bd8 cams running dark greens
Old 11-11-2008 | 08:35 PM
LHD220Turbo
where in the rev range does the boost drop to 12 psi?
how far is the actuator rod wound out? and was it a new actuator supplied with the turbo or have you used your old one?
Old 11-11-2008 | 08:40 PM
p100sr500's Avatar
p100sr500
used the old acctuator it not wound on that far and it drops off about 3-4k when its peaked
IainRS1700T
25-09-2015 07:44 AM
oilman
Trader Parts for Sale.
23-09-2015 12:21 PM
fordjames
Ford Focus Diesel
03-09-2015 11:20 PM
Stu @ M Developments
41
21-08-2015 07:47 AM
