T34 Escos @ wheels power figures..
Old 04-11-2008, 01:36 PM
  #81
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Originally Posted by Lambchop
Sorry but PMSL!
Not reading a thread properly at its finest! FAIL!
Epic FAIL you mean
Old 04-11-2008, 03:35 PM
  #82
SteveH
SteveH's Avatar
Thats an impressive figure martin, I was going to guess about 300 ATW,
Old 04-11-2008, 04:47 PM
  #83
babscossie
babscossie's Avatar
[quote=Lambchop;3711746]firstly, fuck me if someone says t34 escos you HAVE to presume 4x4 as they were built like that. To assume otherwise would be silly and i'm sure Martin would've said had it been different
get your tongue out his arse!!!
Old 04-11-2008, 05:40 PM
  #84
RickyLee53
RickyLee53's Avatar
If use aggressively, it will be spitting exhaust blades every 3 months, as that is the exact pressure I ran mine at .
Back it off to a peak of 30psi, and it should be fine (albeit lower powered). Would be interesting to see by how much .
Been there, lost the blades, bent the shaft smashed the housing etc etc.
7 o'clock on the morning of TOTB, had to change the turbo at the side of the M18 and remap on the way to TOTB
Old 04-11-2008, 05:41 PM
  #85
mechanic28
mechanic28's Avatar
nothing to do this this thread in a way !but would you notice any difference jumping from a T34.55 to one with a .63?with the correct set up for the .63 of course!
Old 04-11-2008, 05:47 PM
  #86
Jay,
Sponsor
Jay,'s Avatar
Originally Posted by mechanic28
nothing to do this this thread in a way !but would you notice any difference jumping from a T34.55 to one with a .63?with the correct wet up for the .63 of course!
yes doug the difference will be a little later to come on boost but more punch middle to top of the range
Old 04-11-2008, 05:50 PM
  #87
mechanic28
mechanic28's Avatar
cool jay i thought the boost would be abit later but was not sure if you would feel it higher up the revs range!as tbh i did not notice much difference from my .48 to the .55!would air injector not help bring a .63 on boost alot quicker by helping get rid of any surge etc?
Old 04-11-2008, 06:20 PM
  #88
Jay,
Sponsor
Jay,'s Avatar
only time ive seen surge on a .63 is when over 30psi on 2wd inlet
on the early boost thing cam timing is the essence of it imo to get the turbo to spool quicker
Old 04-11-2008, 06:21 PM
  #89
RickyLee53
RickyLee53's Avatar
You'd be less likely to get surge with the 0.63 housing anyway. You could add some boost control to gain a little lower down, but could do the same to the 0.55 also.
Old 04-11-2008, 06:29 PM
  #90
mechanic28
mechanic28's Avatar
cool cheers jay and rickylee!
Old 04-11-2008, 07:01 PM
  #91
lawnsy
lawnsy's Avatar
Ive done 2k hard miles in my car last year and a half and onto my 3rd t34....running 36psi peak and holding as much as it can....pmsl...
But its fun..
Old 04-11-2008, 07:09 PM
  #92
bigchez
bigchez's Avatar
But its fun..
Mine's let go after 1500 miles with a 32 peak. But you're right, its great.
Old 04-11-2008, 07:10 PM
  #93
KSA-Cossie
KSA-Cossie's Avatar
36 psi peak on mine too,don't half go well.
Old 04-11-2008, 07:12 PM
  #94
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Running that amount of boost, don't be surprised when the turbo calls time .
Old 04-11-2008, 07:15 PM
  #95
sbd16v
sbd16v's Avatar
i can nver understand why someone would want to keep killing a t34 when they can change to a gt30 with no bad effects
Old 04-11-2008, 07:19 PM
  #96
KSA-Cossie
KSA-Cossie's Avatar
After seing how rich's car was transformed using a gt 30 i was thinking of going down that route myself.
Old 04-11-2008, 07:37 PM
  #97
bigchez
bigchez's Avatar
I'm on a .5 bore on a 205 block, and concerned the extra power of the GT30 would kill it.
Plus I love the chatter on the t34 with no dump valve and would lose that with the GT.
Old 04-11-2008, 07:47 PM
  #98
Jay,
Sponsor
Jay,'s Avatar
i dont think ur engine would be a issue and i would rather have better response and a smoother better topend and put up with a chav valve if you see what i mean lol
Old 04-11-2008, 08:14 PM
  #99
mechanic28
mechanic28's Avatar
mines still on a 205 block and .5 over bored as well!thats why i think i might go up to a .63 and fit a 4x4 plenuim and 14mm spacer and she what that brings!i would hope close to 400 odd bhp
Old 04-11-2008, 08:26 PM
  #100
Jay,
Sponsor
Jay,'s Avatar
to get 400 bhp YOU WILL OVER SPOOL THE FUCKING TURBO read the above posts and see the people that are laughing about wasting money every 1500miles on a rebuilt turbo ! call me a cunt but fools waste money , a gt30.63 will do 400 bhp all day will outlast a t34 at 400+ bhp as it wont be stressed now think about it or doug do i need to send you some anadin
Old 04-11-2008, 08:30 PM
  #101
mechanic28
mechanic28's Avatar
i know,i know jay but i do around 1k a year in mine if i am lucky and say 400 miles of that will be driven hard!my turbo has done around 500 miles max!and is just over a year old!so its going to last a few years i would expect (hope/prey!)compare that to a cost of a GT30 turbo they have got to be around Ł1200 odd !plus with a GT30 it woud be surge city on standard cams and standard c/r
Old 04-11-2008, 08:34 PM
  #102
lawnsy
lawnsy's Avatar
Well ive seen the light...nice fresh T4 .....now lets see how much boost i can squeeze out of that....
Old 04-11-2008, 08:37 PM
  #103
Jay,
Sponsor
Jay,'s Avatar
true true on the cost against mileage but surge ill find out for you im guna bolt one on mine standard cam slightly ported head and a swedish inlet
Old 04-11-2008, 08:50 PM
  #104
mechanic28
mechanic28's Avatar
cool jay!you going to run air injectors?seriously thinking getting one for mine,rather then use the amel valvemy head has had mild porting as well!i presume yours in lower then standard c/r?
Old 04-11-2008, 09:28 PM
  #105
Jay,
Sponsor
Jay,'s Avatar
8.3.1 cr and im useing a vag control valve
Old 04-11-2008, 09:30 PM
  #106
mechanic28
mechanic28's Avatar
cool jay so you going for the higher c/r route then!all the more modern way lol!!!
p.s sorry for the thread hi-jack martin!!
Old 04-11-2008, 10:34 PM
  #107
RickyLee53
RickyLee53's Avatar
I guess it's price for most people, but ye once 1 goes you'd be stupid not to change.
Jay, are you using the N95 valve?
Old 04-11-2008, 10:41 PM
  #108
Chip
*** Sierra RS Custard ***
Chip's Avatar
I recently got a GT30 I sourced for someone who now doesnt need it, .63 backend, 4" front with surge porting, comes with V band adapted outlet, complete with the v band itself and the bit to weld onto the downpipe, and with the actuator etc, 850 quid it owes him so thats all he wants for it.
So they really arent as dear as a lot of people think they are.
Totally perfect for about 420-430 bhp on a cossie and will do 400 SO much more comfortably than a T34 will, and it spools quicker.
People pay about 700 normally for a new T34 IME!
Old 04-11-2008, 10:49 PM
  #109
Jay,
Sponsor
Jay,'s Avatar
yes bud a n95
Old 04-11-2008, 11:29 PM
  #110
BigErn
BigErn's Avatar
36psi
Old 05-11-2008, 07:27 AM
  #111
CossieRich
CossieRich's Avatar
How are people getting surge on a t34?
I so wouldnt bother with a t34 now i have seen the results of the GT30's
Old 05-11-2008, 07:35 AM
  #112
Mike Rainbird
Caraholic
36psi on a standard 2wd inlet plenum !
Old 05-11-2008, 07:39 AM
  #113
CossieRich
CossieRich's Avatar
utter bullshit i had that boost on a 2wd inlet plenum and i also saw more than that boost on inital mapping on the Gt30 and no surge
Old 05-11-2008, 07:40 AM
  #114
Mike Rainbird
Caraholic
Sorry, standard cams as well (according to Jay anyway, as that is when he experienced it) .
Old 05-11-2008, 07:41 AM
  #115
Porkie
Porkie's Avatar
a new T34.63 is over Ł1000 in reality.
trust me I know! as I just bought one!
you can get them alot cheaper with .48 and .55 housings though...
but a genuine new one is over a grand.
Old 05-11-2008, 07:42 AM
  #116
CossieRich
CossieRich's Avatar
Well i use a BD14 inlet so maybe that cures it all
Old 05-11-2008, 08:00 AM
  #117
Jay,
Sponsor
Jay,'s Avatar
im not the only one you fucking turnip farmer
jtech and trevcos come to mind straight away !
Old 05-11-2008, 08:23 AM
  #118
Garage19
Garage19's Avatar
So to summarise... GT30 is better and cheaper than a T34.
...and once more as i know cossie owners get very stuck in their ways.
Old 05-11-2008, 08:27 AM
  #119
Jay,
Sponsor
Jay,'s Avatar
heres another can of worms i wonder how many people are still spending over a grand on porting and a t38 to get 440+ bhp
Old 05-11-2008, 09:02 AM
  #120
CossieRich
CossieRich's Avatar
Well considering i cant find anyone else on here who has just done what i have then there must be a lot of people still doing it, or they are keeping very quiet about using a standard ported head.
Quick Reply: T34 Escos @ wheels power figures..
