Engine characteristics
Old Oct 30, 2008 | 08:11 PM
SteveH's Avatar
SteveH
Default Engine characteristics
If i had some 2 litre engines, in various cylinder configurations and numbers, how would the characteristics differ, in terms of revs, power, torque?
For instance:
(all 2 litre, 4 valves per cylinder, as similar as possible everywhere else)
4 cylinder
V4
5 cylinder
V5
V6
V8
would the V8 have to rev higher to produce the same power, would it be less torquey than the I4 for example? I've always wondered how differing layouts affect power/torque.
Steve
Old Oct 30, 2008 | 09:11 PM
cjwood555's Avatar
cjwood555
There are lots of things to consider - in general the cylinders the more drag/parasitic losses/friction in the engine, so less power would be seen at the fly given the same volume of air and fuel being burnt equally well. In terms of revability, assuming equivalent head designs, equal compression ratios etc, so as to give equal VE's across the rev range, the difference would come from how well balanced the different configurations are, weighed up against the mass of the rotating assembly (specifically its inertia, which is proportional to mass). A 180degree V8 is the best balanced rotating assembly, IIRC, but also the heaviest so although it would feel smoother at higher revs than the inline 4, it would take longer to get there.
Chris
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
