xr8?? are these rare?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
just found this is abit diffrent never seen one before
which XR8, new or old? one is is the SA XR8 and the other is the Aussie XR8 quite different motors personally the aussie XR's are some of the nicest motors ford are knocking out. certainly better than the shit Ford UK are knocking out anyway
just finding my feet
nice colour carpets in em , suddenly my grey carpet looks nice
oh and i belive fastmaul owns a proper xr8, not that xr4x4 wannabe, but a 3 door jobby
no sorry thats actually a xr4Ti
sorry, think the xr8 utes are the tits though, a guy on my road has one
much better than my car and more usefull to collect the fooking doors of switch
Originally Posted by John_bonus90
i saw one at donny park today. it looked smarted.
dont know if it was a proper one
It's quite real and quite nice
Originally Posted by BlueSmoke
Wow never seen one of these before. Is a 4 valve V8 really that good tho?
They are not 4 valve heads,
I'm 99% sure that the 4V part refers to the 4 barrel carb,
meaning that it is a hotter version of the 302.
The XR8 was a homogolation special and was not in a high state of tune from the factory and only existed to allow the car to race in the SA production saloon championship.
Mark
Mark
Mark
Mark
that engine can make good power if splashed with a bit of money, the cars have modded T5's, beefed up rear diff and big disc's with AP's all round. Not to shabby
Just found this
http://www.compcams.com/Community/Ar...p?ID=858512586.
Not too bad with just a cam kit
Mark
Mark
DEYTUKURJERBS
Homologation specials mate, 200bhp std but these engines have been tuned to 1500bhp+ with turbos, and still craaazy power without, even relativley mild mods get you 350bhp, and the prices of parts from the US is mental, 8 forged pistons for under 400quid etc...
Its the same 302ci V8 from mustangs, and its piece of piss to fit to a sierra, real steel sell a fitting kit.
Not the rarest sierra model made
he some spec i found
Ford Sierra XR8 Sedan
Background
Built in South Africa 1984 by Ford South Africa (F.S.A.)
Built to support homologation for local saloon car racing, only 250 were built.
Specifications
Axle, rear
Type: Centrally located hypoid differential assembly with independant open drive shafts
Ratio: 3.5:1
Capacity (litres): 1.5
Brakes
Description: Hydraulic - dual line - servo assisted
Front type: Ventilated discs with self adjusting sliding caliper
Disc diameter (mm): 280.0
Rear type: Disc brakes
Disc diameter (mm): 270.0
Clutch
Type: Cable operated, self adjusting, with single dry plate
Diameter (mm): 255
Total frictional area (cm2): 284
Release bearing: Pre-lubricated
Cooling system
Type: No loss system
Capacity (litres): 12
Radiator type: Pressurized fluid circulation
Fan: Two electric fans, 11 blades each, diameter 305 mm
Drive line
Type: One piece articulated
Propeller shaft number: 1
Universal joints (front & rear): Needle roller
Electrical system
Battery: 440 A/75 RC low maintenance polypropylene
Alternator: 60 A
Ignition: New breakerless, thick film module
Engine
Type: V8 cylinder OHV
Bore and stroke (mm): 101.6 x 76.2
Displacement (cm3): 4942
Output (kW at r/min, SABS): 150.0 @ 4800
Torque (Nm at r/min, SABS): 330.0 @ 3400
Compression ratio: 9.0:1
Fuel system
Fuel pump: Mechanical
Carburettor: Ford/Holley 4 venturi
Choke: Auto choke
Fuel filter: Gauze screen in pump
Air cleaner: Replaceable dry paper element
Tank capacity (litres): 60.0
Lubrication
Engine: Full pressure feed to main, big end and camshaft bearings
Crankcase capacity (litres): 7.0
Oil cooler: Oil to air type
Suspension
Front:
type: Independent McPherson struts
description: McPherson strut front suspension with 15 mm static scrub radius, forged TCA and rearward mounted 24 mm stabiliser bar and parallel front spring design
Rear:
type: Independent semi-trailing arms
description: Frame mounted semi trailing arm and IRS with variable rate coil springs, including rear stabiliser bar
Steering
Type: Rack and pinion
Steering wheel diameter (mm): 382
Turning circle (kerb to kerb, m): 10.00
Ratio: 19.88:1
Transmission, manual
Type: Manual gearshift
Synchromesh: 5 forward gears
Ratios: 1st 2.95, 2nd 1.94, 3rd 1.34, 4th 1.00, 5th 073, reverse 2.76
Capacity (litres): 1.9
Wheels
Type: Cast aluminium
Size: 6.0J x 15
Tyres
Standard: 195/60 VR 15 Steel belt radial ply
Measurements
Weight (kg): total 1279 (front 683, rear 596), payload 400, total weight 1679
Wheelbase (mm): 2608
Rear track (mm): 1468
Front track (mm): 1452
Height (mm): 1406
Length (mm): 4425
Width (mm): 1725
Changed components
ITEM SOURCE REMARKS
Radiator grille Unique F.S.A Source: Trek Plastics
Front body crossmember Unique F.S.A
Front & rear
suspension crossmember - " - Reworked standard component
Rear suspension arms - " - Reworked standard component
Engine - " - Ford U.S. sourced, 302 cid V8. Build code EX-303,
as Mustang minus emissions, power steering and airconditioning.
Uses unique camshaft, water pump and carburettor (Holley 780 cfm)
Radiator Unique F.S.A.
European vendor SERK UK sourced
Radiator support Unique F.S.A.
Cooling fans Two Granada, with air conditioner, fans
Exhaust system - " - Manufactured by Bosal, including engine manifolds
Clutch cable - " - Low friction design, manufactured by Repco
Clutch and transmission Ford U.S. Carryover 1984 Mustang. Transmission - Borg Wagner T5G
(Ford Part No. E3ZR-7003-CA)
Driveshaft Unique F.S.A
Rear axle
(Differential) - " - As used in F.S.A. Granada, 3.5:1 ratio, with new rear
and uprated side shafts
Axle shafts - " - Granada C.V. joints with new shafts
Stub axles - outer - " - To suit Sierra hubs and Granada C.V. joints
Brakes - Front European vendor AP Racing - Leamington Spa sourced, four pot caliper type
Brakes - Rear - " - A Teves Germany-sourced
Alternator and regulator Ford U.S. Part No's: Alt E12F-10300-CA, Reg E2PF-10316-BA
Wheels Unique F.S.A.
European Vendor Ronal wheels - Germany-sourced,
Ford Part No. 84BC-1007-AA
Background
Specifications
Axle, rear
Ratio: 3.5:1
Brakes
Clutch
Diameter (mm): 255
Cooling system
Drive line
Electrical system
Alternator: 60 A
Engine
Fuel system
Choke: Auto choke
Lubrication
Suspension
Front:
Rear:
Steering
Ratio: 19.88:1
Wheels
Size: 6.0J x 15
Tyres
Measurements
Height (mm): 1406
Length (mm): 4425
Width (mm): 1725
Changed components
ITEM SOURCE REMARKS
Front & rear
Rear axle
borboyous
22-08-2015 11:17 AM
