Escort S1 ECU / S2 ECU
Does anyone know what the difference is between a S1 ECU and a S2 ECU???? and will a S1 chip work in a S2 ECU????
Any help much appreciated
I don't think the chips will work in each other....
S1 ECU is a blue red blue ECU with no knock sensor
S2 ECUs are blue red white ECU with no knock sensor
...................blue red black with knock sensor
...................hearts hash diamonds with knock sensor
-- FlashPoint Engineered --
Jay-Cosworth No you can't swap chips from different generation of ecu
It would be better to swap the whole ecu
Steve
Steve
dave isnt there a diffrence with the s1 s2
with the s1 you could run high boost and blow it up easy
but the s2 would try cut out if you run high boost without a chip etc
Both S1 and S2 ecu have a boost limit as standard set at about 8 psi
To run more boost you would have to chip both S1 and S2.
Steve
Steve
