need some help...
Old Oct 19, 2008 | 11:03 AM
R5FORD's Avatar
R5FORD
Default need some help...
Parked the rs500 up in the garage couple of days ago after using it basically everyday day for the last month.. went to start it this morning and the thing wont start, the engine managment light is on.. it turns over fine but wont fire any help would be appreciated
Old Oct 19, 2008 | 11:08 AM
AndyPen's Avatar
AndyPen
Fuel pump making right noises?? If not theres your problem - check the wiring and the fuse behind the dash. Also does the relay in there sound clicky?
Next step would be to wiggle the crank sensor and recheck
Good luck - assume the plugs have been checked? Wet with fuel rules out my first point
Old Oct 19, 2008 | 11:13 AM
R5FORD's Avatar
R5FORD
does the engine managment light come on if the pump isnt working?? its making all the right noises and stinks of petrol
all plugs have been checked..
have not tried the crank position sensor tho.. il give it ago tomorrow.
any more ideas??
Old Oct 19, 2008 | 11:16 AM
AndyPen's Avatar
AndyPen
Next guess would be to check inside the dizzy cap to see if the wires are freyed in there. They can short out as the cover plastic wears off during movement.
Do you have a spark? Have you clipped and unclipped the ECU as someone on here simply did that to sort the problem a while back?
Old Oct 19, 2008 | 11:17 AM
AndyPen's Avatar
AndyPen
Stinks of petrol?? What chip are you running - not simply flooded is it??
Old Oct 19, 2008 | 11:26 AM
R5FORD's Avatar
R5FORD
nah its not flooded mate.. the engine managment light is on tho
Old Oct 19, 2008 | 11:44 AM
AndyPen's Avatar
AndyPen
How old is the crank pos sensor? Get a new one if I were you if thats the apparent prob. Good luck
Old Oct 19, 2008 | 11:59 AM
mechanic28's Avatar
mechanic28
sell it to me!
Old Oct 19, 2008 | 12:04 PM
babscossie's Avatar
babscossie
stinks of petrol???
sounds like you have no spark. see if you have live (+ve) to both sides of the coil with the ignition on.
if you have, see if there is a spark at the coil.
Old Oct 19, 2008 | 12:08 PM
Nash's Avatar
Nash
Cake lover!
Check all of your earths.
Old Oct 19, 2008 | 12:36 PM
Paul_RS's Avatar
Paul_RS
I'd try crank position sensor and phase sensor first mate. I'm guessing the pump is ok as its buzzing away.
Dr. Ickxs
Aug 15, 2015 11:34 AM
bassboy
Aug 5, 2015 08:21 AM
drsrst2zvh
Mar 30, 2008 09:54 PM
RS-adam
Apr 27, 2005 11:23 PM
skillicky
Mar 29, 2004 09:15 AM
