wireless network connecting problems
Old Oct 18, 2008 | 05:46 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default wireless network connecting problems
i've got the connection connected
it's sending packet data
it's reciving packet data
but it's not connecting to the internet because it's still at the "acquiring network address" stage
and there are 2 lines for the ip address which say 0.0.0.0 and 0.0.0.0
whats wrong?
i've put all the details i need in, i've got the connection, why won't it connect?
i can't even put in a manual ip address into the bar anywhere but i can connect to next door neighbours laptop and see what he's got on his system
help
Old Oct 18, 2008 | 05:50 PM
northernmonkey's Avatar
northernmonkey
I didn't do it!
not on sky in Kent are ya? See my other post! LOL.
Old Oct 18, 2008 | 05:55 PM
dojj's Avatar
dojj
got 100% 5 bars on the signal strength and everything else is working fine
i've been connected for 3 days but can't get onto the intenet wth the wireless
using the computer downstairs and running a wire up the stairs for the laptop
Old Oct 18, 2008 | 05:58 PM
turbotoaster's Avatar
turbotoaster
try this
click run and type services.msc
scroll down the list until you reach 'wireless zero configuration'
right click and go to properties
either click start or restart, which ever u see
and the startup type should be set as automatic
if that does work and ill have another think
Old Oct 18, 2008 | 06:02 PM
dojj's Avatar
dojj
Originally Posted by turbotoaster
try this
it says:
provides automatic configuration for the 802.11 adapters
what does that mean?
i restarted it anyway
Old Oct 18, 2008 | 07:01 PM
T38Mat's Avatar
T38Mat
Sounds like an encyrption issue. Make sure your wifi on the unit that doesnt work is compatable with the encryption of the router eg unit only supports wep and router is on wpa.
Id turn off the encyrption (on the router)for a minute, try to connect, if it works then try it on wep, then move higher to wpa etc.
good luck.
Old Oct 18, 2008 | 07:09 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Did you do the age old reboot before trying anything else?
i.e. turn router off for 3 minutes, turn machine off, turn router on allow it to re-initialise then boot up machine.
Old Oct 18, 2008 | 07:12 PM
dojj's Avatar
dojj
the thing is, the laptop was workign fine when my brother had it a few months ago
since then, i've connected the same laptop to teh same system and it just fails
i can easily turn everything off tonight and start it up again in the morning, but what does this wep and wpa stuff means?
Old Oct 18, 2008 | 07:15 PM
LHD220Turbo's Avatar
LHD220Turbo
dojj
click start, run, type 'cmd', type 'ipconfig'
make a note of your ip address, likely to be 192.168.1.1
if it is
type 'ping 192.168.1.1' or what ever the IP address is
do you get a reply?
Old Oct 18, 2008 | 07:16 PM
LHD220Turbo
encryption for the wirless network
Old Oct 18, 2008 | 07:17 PM
T38Mat's Avatar
T38Mat
wep and wpa are just different types of encryption thats all - wpa is better though.
try rebooting etc and try what I sugguest.
Mat
Old Oct 18, 2008 | 07:26 PM
turbotoaster
my advice would be to disable all security on the router aswell aswell at least for the moment, i use a wireless dongle with seperate software so my advice would be to re install that but urs will be set in the laptop so let us know how u get on with other peoples suggestions first
Old Oct 18, 2008 | 07:29 PM
dojj's Avatar
dojj
the battry's gone flat so it'll have ot wait till tomorrow now
but the ip address of this computer and the laptop are the same (i'm not sure if they should or not seeing as they are different computers but running off the same connection) so that's that sorted out
the ip address is nothng like 192.168.1.1 though
it 2 numbers.3 numbers.3 numbers.2 numbers
Old Oct 18, 2008 | 07:41 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Are you with SKY? You can get your Netgear router information from http://192.168.0.1/ , username ADMIN and password SKY. Don't know if you know already?
Old Oct 18, 2008 | 08:02 PM
dojj's Avatar
dojj
thanks
that info confirms what i already know, but has also opened up the wireless connection option so i'm goign to let the mrs fuck about with this for a while later on tonight as she's desperate to get rid of the wire trailing up the stairs
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
biggiejody
Sep 19, 2015 10:25 AM
Flatlinedan
Sep 18, 2015 12:41 PM
