Dump valve on cossies discuss
I have had 3 cossies & never had dump valves as i like the wastegate chatter best noise ever IMHO..
But im on my 4th cossie now & trying to buy all the right bits to make it a bit more decent running wise & bought a grpA forge dump valve from woodford not for noise just for its purpose!
1. Are forge grpA any good
2.What do you reccomend?
3.The bailey recirc dump valve i could get one of them & buy a new boost pipe for the other side going into the turbo.But how do they sound i hate the little dull noise from the bailey ones will i still hear the wastegate chatter with the recirc?
If you're not running 30psi of boost a T4 or GT series turbo you don't need one is my understanding. From memory there are even arguements that a dv can cause the turbo to overspeed.
Ave got a forge one on mine and a cone filter makes a nice wastegate chatter then ya get the swoosh of the dump valve.sounds better than the bailey one i had previous on my rs turbo was.forge was on car wen a bought it so don see point changing it or removing it.think a either love or hate thing
i had a le mans one on mine and it was fucking loud a loud at 30psi - you also got to hear the chatter first then the whoosh - i used to play games on the motorway by letting it build up boost and then slowly letting my foot off the gas to see how long I could hear the air seeping out of the dumpvalve - well its certainly makes a long boring journey a bit more interesting - or you could build up boost and let off right next to someone to see their reaction when they shit themselves
Colossal Pervert
T series turbos are a lot stronger than GT on the whole.. anything below a T4 will generall survive without a dump valve.. I wouldn't run any GT without a recirc valve..
ours didnt have a DV when was on t34 and chattered like foook but on th t4 we fitted one, it still chattered loads though but not a dead loud tschhh from dump valve. Ours was a Spec -R one iirc
Sarah
Sarah
Fucking superstar........
Every dump valve I've ever owned thats not been a factory fit item has leaked like fuck. If it's OE then keep it. If it's aftermarket them ditch it. Unless you're running 2 bar on a T4 or something....
The more turbos,more fun!
Im running a Baileys DV26 tiwn piston jobbie on my celica and its bloody loud when ruinning 1 bar!
And as for the comment of dump valves being chavvy, i dont understand why they are?
Cornish Fasty
I took off my leaking dv a couple days after buying the car, snapped the turbine wheel right off on the drive back from work.
not particulary impressed.
are we off the opinion that less than 30psi and its safe to let it chatter?
Beacuse people fit those fake ones to their Saxos and what not... It sounds like a bus anyways.
i had a dv26 on my calibra turbo was spot on,i no many people who have used them and not had problems. i no scobby boys dont recomend bailey's ones. aprantly theve det a few scoobys
http://uk.youtube.com/watch?v=nhKyfwFIeHw
this is mine, baily twin piston fitted to a big turbo conversion (on small turbo engine) peaking at 1.2 and holding 1 bar.
I can lube the dump valve up and loose the chatter, but I love the chatter
sideways all the way!
ive got a dump vavle on my cossy,not sure witch 1 it is but it dumps all the time,even at fuck all revs,never give me ne hassle so never considered taking it off,dumps quick or slow with the way you let pedal up,but its loud all the time
i used to run 34 psi no probs without one
Hows this fella? it chatters from the filter first then dumps from the valve chatter is the wastegate opening if am not mistaking? which needs to happen for boost pressure to be released to the dump valve or am a wrong in saying that?
