siemens injectors , what did you do to your fuel rail ??
fitted mine to the es cos yesterday
they are shorter than bosch ones i think and only just fit if you leave the o rings visible
anyone else had this and what did you do ??
More boost Igor!
I thought they were a direct replacement.
Make sure you lightly oil the O-rings then attach the rail, then as you bolt the rail to the plenum the rail will push itself into place on the injectors. You'll need to wiggle the injectors into place to make sure they're secured in the rail.
yes they are in but only just, i know scott had the same problem......
just look a bit dodgy to me ??
was thinking of modifying the fuel rail ?
escort mk4 cossy 4x4
the siemens injectors are shorter,but do fit loosely.
get hold of a set of o rings to go in the manifold side.same size as the ones used on the 4x4 cos fuel reg.
DixieTheKid
11
06-06-2020 11:20 AM
timsrs
22
24-09-2015 08:14 PM
