engine blown?
Old Oct 9, 2008 | 08:31 AM
KW-rscos's Avatar
KW-rscos
Default engine blown?
came off a dual carrige way last night and as I came off the round about into the village the engine started to click badly and I lost power, power is fine upto 30mph, but the goes after that and the car sounds like a scooby under any acceleration (eg pulling away) and there is a high pitched screech. its a cvh efi, any ideas? limped it home and it will start, but dunno what it is, oil is fie, no bits in it, nice colour temperature never went above normal,
any suggestions? only need it to last another month or so, or am I going to need a new engine?
Old Oct 9, 2008 | 08:33 AM
Rab's Avatar
Rab
Fucking superstar........
Headgasket gone between 2 cylinders? HAd that happen to me before, epecially if its not a Ford Gasket.
Old Oct 9, 2008 | 08:38 AM
KW-rscos's Avatar
KW-rscos
is it easy to change in situ?
Old Oct 9, 2008 | 08:40 AM
Rab's Avatar
Rab
Well, you'd need to take the head off.... But you can do it with the engine in place yeah. IF thats your problem. Have you done a compression test to see where you've lost compression?
Old Oct 9, 2008 | 08:43 AM
KW-rscos's Avatar
KW-rscos
no, I havent had a chance to do anything yet, gonna go out after a cup of tea, how would i do a compression test, is there specific equipment needed?
Old Oct 9, 2008 | 08:51 AM
Rab's Avatar
Rab
Yes mate. A compression tester. Cheap, at about 20 odd quid ish.
http://www.justoffbase.co.uk/Petrol-...9&category=124
You remove the plug on each cylinder in turn and then turn the engine over on the starter and it'll give you a reading. You must remove the fuel injection/coilpack multiplug or similar relay so it doesn't start on you. Then you'll have the compression figures.
If one or two is low, you can then concentrate your efforts there to see why it's low. If they're all fine time to investigate the ignition system.
Old Oct 9, 2008 | 08:52 AM
saphycozzie-adz's Avatar
saphycozzie-adz
go to your local car spares place and get a compression tester Ł10-Ł15. Whip the plugs one at a time and screw the tester in and then turn the engine over. I have been there my self and it turned out i had burnt a hole through a valve and a had zero compression on one piston and it sounded like like a scooby.
Old Oct 9, 2008 | 08:58 AM
saphycozzie-adz
beat me too it lol.
KW-rscos's Avatar
KW-rscos
cheers lads will try that, what reading am i looking for?
Old Oct 9, 2008 | 09:10 AM
saphycozzie-adz
more than zero hopefully!
you will get an idea of pressure from the good cylinders and it will be obvious when you see a fault.
Old Oct 9, 2008 | 09:11 AM
Korda's Avatar
Korda
they should all read the same i had mine tested the other day your need someone to crank it over so you can do the reading good luck
Old Oct 9, 2008 | 09:52 AM
KW-rscos's Avatar
KW-rscos
just about to go to the motor factors now, but listening to it now, it soulds top end somewhere, so i will get some bits, and let you know my findings.
Old Oct 9, 2008 | 11:35 AM
KW-rscos's Avatar
KW-rscos
well, had the lifters out and two of them are solid, the rest are fine, but might this be my problem?
Old Oct 9, 2008 | 03:43 PM
KW-rscos's Avatar
KW-rscos
well, new lifters didnt sort it, but there is deffo piston to valve contact, hat else could cause it? valve springs fine, all the rockers are fine, could the came cause it? though the lobes looked fine.
Old Oct 9, 2008 | 03:55 PM
Rab's Avatar
Rab
Have you done a compression test? What were your results?
Old Oct 9, 2008 | 05:18 PM
Reid's Avatar
Reid
timing jumped a tooth?
Old Oct 9, 2008 | 07:19 PM
KW-rscos's Avatar
KW-rscos
nope, couldnt get one in the motor factors down the road and with no car its too far to the next one, will get one before the weekend and hopefully have a go sunday.
Ried, I can see what you mean, but is this common/surely it would happen under load not cruising?
Old Oct 11, 2008 | 01:11 PM
KW-rscos's Avatar
KW-rscos
well here we are, had the head off and found the pistin is hitting the head, what could cause this? also can anything be summised from the condition of the head bolts?
any suggestions?
Old Oct 11, 2008 | 01:17 PM
born_again_kid's Avatar
born_again_kid
91 FRST
you would really need to take that piston out to find your answers. If you say it was knocking it is likely to be a big end bearing failure but until you take it out you wont know for sure
Dave
Old Oct 13, 2008 | 09:45 AM
KW-rscos's Avatar
KW-rscos
Right then guys, have had the offer of a 1.6 efi for 100 quid, but mine is a 1.4 efi, if i get the ECU as well will it work in my car if i just drop in the 1.6 and swap the ecu's??
Old Oct 13, 2008 | 10:05 AM
KW-rscos's Avatar
KW-rscos
or could i just swap the bottom end over?
Old Oct 13, 2008 | 10:20 AM
KW-rscos's Avatar
KW-rscos
come on guys im in a real pickle here and i need it up and running asap, i know its not a cossie engine but someone must know!?
Old Oct 13, 2008 | 10:21 AM
Nash_mr2's Avatar
Nash_mr2
ignore
JoeyBoyden
20
Aug 22, 2015 03:23 PM
