E46 M3 Help .......
Old Oct 8, 2008 | 03:13 PM
Tony Ryan's Avatar
Tony Ryan
Default E46 M3 Help .......
How do you get the gear knob off when taking out the gearbox ? Cant see a way of getting the leather gaiter off the stick to pass the stick out underneath or even out the top , especially as you cant see the bolts on the linkage to undo from the gearbox ?
Im taking the gearbox out of a roadcar and its doing my head in !!
Old Oct 8, 2008 | 03:23 PM
Luca's Avatar
Luca
Lukesville
Is it illumanated type?
If it is NOT !
Then simply put hand either side and pull up hard watch ya face though when it goes for a right hook!...
Simply located by a spring clip in the knob and a groove on the stick.
If it is i have not a clue
Old Oct 8, 2008 | 03:26 PM
Doug's Avatar
Doug
Tony all has to be done from under vehicle prop and exhaust is off i take it ? remove heat shield then you will see a pin that is in the back end of the box that attatches to the gear lever remove the spring clip and hopefully hey presto !.
Regards Doug ,
Old Oct 8, 2008 | 03:32 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Look at the gear lever where it meets the linkage underneath the car. There is a rod connected to it which goes to the gearbox, that rod has a shaft which goes through the bottom of the gear lever and is only held on by a spring clip. If you pop off the spring clip you can then release the rod and forget about the lever.
I hope that makes sense.
Old Oct 8, 2008 | 03:35 PM
Dangerous Malcolm..
See HERE.
Old Oct 8, 2008 | 07:17 PM
Tony Ryan's Avatar
Tony Ryan
Sorted , thanks lads , pulled like fuck and avoided whacking myself in the chin !!
Oranoco
41
Feb 11, 2016 01:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Ebonycossie4x4
15
Sep 2, 2015 11:40 PM
Lee Reynolds
85
Aug 10, 2015 05:56 PM
Big G
Aug 5, 2005 01:05 PM
