heated seats in a cossie
Chief Iron Oxide Farmer.
You can do it yourself if you dont mind modifying the existing seats.
Buy some heated seat pads from ebay.
Slip these in-between the seat cloth and the foam. (you have to remove the seat cloth for this)
Lop off the fag lighter connectors and wire them into a proper switch on a fused line.
Job done.
Job done.
Resident Wrestling Legend
find some granada seats that are heated
make sure there is a curcit for the rear and for the base
assuming the both work strip them to remove the heater pads
strip your seats and put the heater pads back in again
then you need to wire them up
you have power from the battery
you fuse that with a 30 amp fuse
run it to the switch
the switch sends the power to a timer relay
then around the pads
then back again
there is also a wire for the lights in the switch too so the little seat gets illuminated
the timer relay you need is the 4 minute on, the same as the one for the hot screen at the front
and job jobbed
i did this, ooh, at least 10 years ago, just make sure that the switched power you take off is from the engine running side of things
then back again
and job jobbed
