Max of 2wd T3
Newbie
Max of 2wd T3
Hi!
Anybody knows wich is the max power done by an hybrid 2wd T3 turbo with the T34 compressor fitted?? (I think you call that a T34.048) on a stock engine with only greys, rs500 ic and 3" exhaust
I have greens at 1.3bar with the std turbo and want to go further but dont know what will be the best turbo movement without expend lots of money...
regards
regards
Last edited by Ima_2WD; 06-10-2008 at 07:25 PM. Reason: adding the Ic to the specs
Newbie
hehe! the only problem is that i live in spain and here is only a cossie preparator and I think it doesn't make live maps and things like that,only have parts for sale
About 370bhp is a realistic figure. You don't need a live map. If you call Motorsport Developments, they will post you a chip for that exact spec. Makes for a very fast and easy to drive road car.
Newbie
In other posts i see that T34's are capable of 380bhp on stock engine specs but due to the smaller size of the exhaust housing in t3 I was thinkin it won't be possible
Yes i'll mail to MSD very soon I thoguht
The turbine is not the limiting factor, it is the .42 AR of the compressor housing at this power level, it overspeeds the turbo much more than a 4wd .60 AR and the blades can actually touch the casing, so depends on whether you have the 4wd ar size or the 2wd ar size machined out to take T34 trim wheel ?
SMILER258
28-09-2015 09:04 AM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
