What The Best Oil To Use In A Cossie
Hi there i have just had a full rebuild done and was wondering if anyone can give me advice on the BEST oil to use?cheeRS for taking the time to read this
saff is working!!!...atm
are u onabout running in oil...???.........if so use mineral 10/40 (or what ford recomend in the book) for a good 1k.........then i'd use a fully synth 15/50.....mobil 1,silkolene,millers....
What grade is best to use?
I'm going to use mobil 1, I don't think you can get better. When you open up an engine that's been run on mobil 1 for its entire life and nothing else it's in alot better condition and alot less sludgy than others.
ok guys i think i will go with silkolene pro s 10/50 i used to use mobile 1 in my other cossie but after spending alot of money on this one i want to have it perfect cheeRS guys
Only use 10/60 in my cossie's, being that bit thicker seems to help consumption,no jokes about the driver being thicker ither mr anderson
cheeRS stu
cheeRS stu
Happily retired
Happily retired
Thats what I thought about Castrol RS, untill I was asked to do tests on it. big shock. Wont go into details but oil was below optimum Spec after a single 200mph run. No one is saying that other oils will destroy your engine but it will be wearing it out quicker than some others, Tests are a real eye opener, MAD & Mike Rainbird recommend Silkolene as their prefered choice for the YB engine following the tests that I did.
I'd love to see the same tests done on say a 400bhp Cossie
Happily retired
