de-carbing an engine?
right, im having a bit of trouble with carbon in the engine, its been runnin rich for a while and when you stop the engine it re-ignites (and cause its runnin on carbs,- runs on...
whats the best way to de-carb the block without taking the engine to bitS?
try this stuff m8.
http://cgi.ebay.co.uk/10K-BOOST-EMIS...d=p3286.c0.m14
i've put it through the saph. seemed to clean it out pretty dammed good!
just be warned after it's done an you take it for a short run it'll smoke like a bastid!! i thought i'd fooked the engine but aparently it's just the shite getting burned off..
i've got gallons of redex from about 1940 in the shed , bloke at work gave it to us when he found it in his dads shed, aparently garages used to use it when you take your car in for a de-coke, take the plugs out, stick a bit in the bores, let it soak for a few mins, turn it over a few times by hand then start her up, tried it on the 205, by god does it smoke! can stick a bit in the carb aswell.
