help escos problem!!!
Old Oct 2, 2008 | 08:42 PM
martinembleton's Avatar
martinembleton
Default help escos problem!!!
hi just put my car back together after blowin the inner joint on he drivers side drive shaft and tryed to drive it down the road and it feels like your drivin over logs!!! lol when u jack the car up u hand turn the front wheels easily!!!wot do u reckon i have broken?????
cheers
martin
Old Oct 2, 2008 | 08:50 PM
dave cos4x4's Avatar
dave cos4x4
is the engine mount ok.
dave cos4x4
they go and cause the joint to fook up.
Old Oct 2, 2008 | 08:55 PM
martinembleton
ok i will check but will that make the car dive like ur drivin over some one lol???
Old Oct 2, 2008 | 08:58 PM
Kelv's Avatar
Kelv
Almost there!
have you checked your rear view mirror, they may be seriously hurt!!
Old Oct 2, 2008 | 09:00 PM
martinembleton
i didnt even get off the drive so they should be ok
Old Oct 2, 2008 | 09:01 PM
Kelv's Avatar
Kelv
Almost there!
Seriously tho mate....
have you checked the hub nut, the front wheel could be wobbling all over the place!!
Old Oct 2, 2008 | 09:05 PM
martinembleton
yer thats all tight and wheel nuts
Old Oct 2, 2008 | 09:12 PM
Kelv's Avatar
Kelv
Almost there!
then just back track everything you have undone and double check.
ARB is tight to the chasis? also tight to the TCA? TCA tight at each end?
you havent undone the top of your suspension strut in an atempt to drop the hub and over sighted that?
and your certain the hub nut is tight, and the shaft joint is fully home into the hub?
Old Oct 2, 2008 | 09:16 PM
martinembleton
yer i will check every think again tomoz
Old Oct 2, 2008 | 09:17 PM
ECOS95's Avatar
ECOS95
Should you be able to turn the front wheels easily. Surley the diff should put up some resistance.With one wheel lifted you can feel the resistance when you try to turn the lifted wheel.
Old Oct 2, 2008 | 09:22 PM
martinembleton
i had both wheeels up
gcfcos
59
Oct 6, 2015 05:04 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
