4x4 diff ratio's
Old Oct 2, 2008 | 04:52 PM
westus1's Avatar
westus1
Smile 4x4 diff ratio's
anybody know what diffs to use on a 4x4 cossie to pick up the acceleration
is it just aftermarket crown wheel and pinions
or is there any other diffs that swap in out of something else? i.e xr4x4 etc?
Old Oct 2, 2008 | 04:55 PM
Mad Matt's Avatar
Mad Matt
Rally nut
You have to get both the rear diff and the pignion/chain, otherwise you'll break everything.
Old Oct 2, 2008 | 04:59 PM
westus1's Avatar
westus1
out of what?
Old Oct 2, 2008 | 05:06 PM
Mad Matt's Avatar
Mad Matt
Rally nut
pignon/chain are in the transfert box.
Old Oct 2, 2008 | 05:09 PM
westus1's Avatar
westus1
i know that
i've had them out many times doin viscous's
i meant what 1's do i want to be putin in them
the diff and chain drive out of what mate?
Old Oct 2, 2008 | 08:38 PM
westus1's Avatar
westus1
bttt
Old Oct 2, 2008 | 08:49 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Use diffs out of a 2.0 xr4x4 as they are 3.9 as opposed to standard 3.6
Got them fitted to mine and transformed the car
Old Oct 2, 2008 | 08:51 PM
Kelv's Avatar
Kelv
Almost there!
Ditto, most definatly worthwhile changing if you can.
but as said above, you will need to change the step offs in the transfer box to alter the front to 3.9 to match the rea diff.
Old Oct 2, 2008 | 08:53 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
2.0 xr4x4 front diff is a 3.9 Kelv. Not as strong as 3.6 hence why people run standard front diffs with the 3.9 step off
Old Oct 2, 2008 | 09:00 PM
Kelv's Avatar
Kelv
Almost there!
yeah i know Rich, thats why ive only ever changed the rear diff and kept the front standard, 3.9 fronts are weaker than rondells
and the same ratio step off's apply now with the Quaifes and Barra
westus1's Avatar
westus1
thanks guys, want it to pick up a bit quicker on track
so do i still change the chain drive if i use the xr4x4 front diff then?
Old Oct 2, 2008 | 09:05 PM
Kelv's Avatar
Kelv
Almost there!
you either change the rear to a 3.9 and then alter the transfer box ratio's so it makes the front drive as if it were a 3.9.
or
you fit a matching pair of 3.9 diffs, ie the ones from an 2.0 4x4 - but thosefront diff are pretty weak.
the most common practice is to go for the first option.
Old Oct 2, 2008 | 09:11 PM
westus1's Avatar
westus1
right got it now
thats even better then
i didn't want to swap the front diff
dont mind the back 1 or pulling the box apart
so i'll go with that option
thanks for the help guys
p.s if anybody's got any for sale pm me
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
