Another BMW E30 question...
Old Oct 1, 2008 | 08:09 AM
Willem's Avatar
Willem
Default Another BMW E30 question...
Do shock absorbers and springs of a E30 325ix fit an 320i??
It'll probably sit a little higer as the 320i is lighter, but I don't care.
Old Oct 1, 2008 | 10:45 AM
If you phone bmw they will tell you if the parts number are compatible to each model ,not sure though as the ix is 4wd so you may have some difference in shock thickness
Old Oct 1, 2008 | 05:49 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
a 325 uses 51mm diameter shocks. a 320 uses 45mm shocks. i dont know about the ix specific differences.unless its a touring like my sig then they all use 51mm struts. the springs will be the same on a 320 and 325 as theyre both 6 pots. touring spprings are stiffer than saloon springs so wont give the same ride height if interchanged..
Old Oct 1, 2008 | 05:57 PM
Willem's Avatar
Willem
Thnx for that info m8, so they differ in diameter, but are the wheel hubs between them the same? The ix will differ from that for sure at the front, but nice to know if that's the same on 325 and 320.
Old Oct 1, 2008 | 06:00 PM
fuzzy's Avatar
fuzzy
go to www.e30zone.net for all your e30 answers
Oranoco
41
Feb 11, 2016 01:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
`spotty
Sep 25, 2015 11:41 PM
Kam B
Sep 24, 2015 10:40 AM
