205 blocked engine
205 blocked engine
i am wanting more power over the stage 1,what is the highest power the 205 block will take,i am thinking as its lowish milege to take it to the max of the head/cams/block/etc,around 400bhp feasable and would it be reliable at this with say one of those msd chips on level 6 ecu,would like to just up the turbo size to say t34 or t4 put bigger injectors in and put a grp a pump on,its on the standard original clutch and head gasket!Am i asking for trouble
My old spec was
radtec 500 cooler
t34 .63
greens
alco 6 paddle with standard ford cover
mapped by msd
all on a standard engine
The car was very quick, and proved to be reliable and imo a perfect spec for the road
radtec 500 cooler
t34 .63
greens
mapped by msd
its good for 450hp in my opinion, ive seen some run as much as 530hp, but that depends on which rollers you use
i would say 200 block for anything above 500hp
edited to say; the clutch will be struggling at that power, a t34.63 will make 400hp
big_Rad
15-09-2017 09:36 AM
James Porter
28-10-2015 12:17 PM
Zoggon
10-08-2015 10:39 AM
