My Car on the rollers - Update 16th Feb 2010
#161
you car IS faster than before so its NOT been a waste of money.
but if it does not make as much power as before does it really matter, the car IS faster, the only place it will be slower will be in your sig
#163
Yes it does, I didnt have a problem with a stock RS500 running 2bar as soon as the turbo could make it with no capping,
The only engine I have had surge with was a ST with a UT T38 with a ported head and stock cams, This started to surge running over 2bar around 3.5krpm.
Mark
Mark
#164
Fucking superstar........
But why? It's just a number......... It could be wrong. The rollers might be out of whack. Any number of factors could make the rollers under read. As long as the car feels faster than it was before you spent the dosh....
Too many people spend the money to get a number. So they can have a sig with how much power in it. Waste of money unless you're out there enjoying the car.
#165
Mark
Mark
did you have proper spec cams for the stock 500 at 2 bar ?
when i got it it was surgeing a bit but running 26 psi low down and it made 390 lbft.
#166
#167
mine has absoluteley no surge and runs 22 psi to 4700, 25 psi to 5300 and 32 psi to 7800 on 14s. could of run more sooner but i wanted it reliable so asked for no surge at all.
Mark
#168
Caraholic
I was of course referring to 10k running the GT30, but as you have run 7-8k on the T34 I will reduce that to an additional 5k of hard driving (including 5 track days) to be fair to TIB. Also, if I win, I'll donate the Ł10 straight to you Rich, as I wouldn't wan't to prosper from your misfortune .
#169
well yes but im not into number chasing. The t34 setup would have been between 370-380 as i was running the turbo and greys as hard as possible. The car cant feel faster without more power and i want to know what that power is. If that power is the same as what i ahd before then i dont have a faster car, i'm a dick head for thinking it feels quicker and i have wasted money. Everyone says you cant get over 400 without head work. Myself and Mark wanted to see if thats true or not.
Mark
#171
But even if you do, someone will come on here and spend 20 or so minutes typing out a huge essay on why you're wrong.......
#173
mark shead this totally stock rs500 at 2bar,did you have to alter cam timing at all and what power would it make?i ask because i have a stage one and am tempted to put on a t4 and bigger injectors but i fear surge through the ports being to small?
#174
No engine spec changes were needed or made.
Mark
#176
#177
there is no reason what so ever for the ecu to help so there is no reason why it will on a L6.
Mark
#178
*** Sierra RS Custard ***
Im sure it will do at some point, there has to be an issue somewhere there I should think.
Although it could be that lowish comp and a standard head is meaning even with lots of ignition timing its not working the mixture hard enough at the top end.
Could also of course be anything from leaking head gasket (mike would love that, PMSL) to lifters that are worn, or any number of other things.
On the plus side, thats still not actually a shy figure for a cossie and its still in one piece and still going very well.
Im sure Mark can provide more info when he gets back.
#193
Shame............at least they are trying something new in this 20 year old game
sure they will have it sorted, gotta be a restriction/leak somewhere i would guess
#194
DANISH cosworth abuser
i did one in april, escos with std engine, 2wd exh manifold and bd12.
Its on light blue and std t34 @ 1,9bar, it max out the injectors, and it´s shit fast
Havent been on the rr yet tho but guessing 360-380
#195
I wasn't too far out either with a 350bhp guess but Fletchcossie was spot on so well done mate . Don't ever be disapointed with 380bhp on the DD rollers as that is a great result and will go as fast as all the so-called 500bhp passionford cossies that only run on the "pub" dyno !
#198
Caraholic
I personally think (as much as I don't want there to be), that there is a problem with the car. It should have pissed 400bhp.
Were the ACTs monitored, as in did Mark go with you and have the lap top plumbed in for the run to monitor everything?
It may have hit the charge air retard point and fucked off a load of ignition, as 2.5 bar is a huge ask of any intercooler with rolling road cooling?
#200
Honestly there is soooooooooooo much bullshit bhp quoted down the pub that a TRUE dyno-dynamics 380bhp sounds crap BUT it's not . This is a great result and he will have soooooo much fun waisting everything and then telling them he beat their "500bhp" pub dyno cossie with his proper 380bhp one !
