My Car on the rollers - Update 16th Feb 2010
#82
*** Sierra RS Custard ***
I was laughing at your optimism, I'd already posted a "" .
Regarding Chip's comment (thanks for quoting it Doug ), he can assume Mark doesn't know what he is doing and that at 2.2 bar it will be 350bhp, and I'll assume that he does and it will be more like 440bhp.
We'll see who is nearest on Thursday ?
I said nothing of the sort, so dont put words into my mouth just to try and hide the fact that yet again you are spouting utter nonsense when you havent got a clue what you are on about.
Stop pretending you have the first clue about things like compressor maps when you clearly DONT, as it just confuses other people who are trying to learn.
All that map tells you, is a vague range of possible values at that boost level, nothing specific at all about what power it will make, if you knew what a compressor map represented you would realise this like the rest of us do!
#84
No, you couldnt.
That turbo at 2.2 bar will flow between 33 and 46 lbs of air and still be comfortabley on the map, so all you could tell is it would be between 350 and 480bhp, you cant tell ANYTHING else from the compressor map of that turbo with regards to how much power it will make at that boost, so athough i am right and you are wrong on this subject i feel we have been letting a silly little disagreement get between our friendship and it has been affecting the generally good camadarie on PF. I think we should draw a line and become buddies again, kiss and make up, and resume our friendship with some light hearted banter about man love
Mike, didn't realise you had Chip on "ignore".
I actually cut the non factual bit off the bottom before quoting it. Full version above.
#85
LOL @ Doug.
Ive got nothing at all against Mike, and just everything against utter nonsense, ANYONE who had said the same utter rubbish that Mike did, would have got the same response from me, nothing personal about it at all, I would just prefer PF to be full of accurate information not the slander and technical nonsense that Mike occasionally wanders off and engages in like he has done in this thread (it always seems to be the moment MAD is mentioned that he spits his dummy out on here, but maybe thats just co-incidence).
Mike doesnt like being corrected and he doesnt like people pointing out when he is being a total hypocrit like happened recently when I pointed out what utter shit he was talking about dynos, so he has thrown his toys out of the pram and declared that we are no longer friends and all that childish nonsense
Personally I cant see the point in falling out over someone correcting someone else on the internet, it gets corrected, everyone realises he was talking nonsense or being a hypocrit again, and that to me then is the end of it, and it shouldnt effect offline friendships.
Im not going to judge him as a person just cause he posts nonsense on here, and I dont see why he would want to judge me just for correcting him when he does it.
#94
Caraholic
Hence I have given a figure of 440bhp based on a best guesstimate on the c/r you have posted, the assumed ignition values for that c/r (late teens on the top line), the compressor map for the turbo and the boost you are going to run.
Jay,
I would "guess" at 360-370bhp .
#96
Because from the compressor map he is saying there is a possibility Mark will only see 350bhp @ 2.2 bar, whereas I have looked at the compressor map and thought that Mark will get the most that the turbo can achieve at that boost (with a small reduction for head port size) .
I know from personal experience he wont see 350bhp, but there is NOTHING on the compressor map that tells me that to be a fact.
#101
Sponsor
Jay,
so the answer mike 280 bhp with 8 degrees of ignition so the next run i added 5 degrees from 5000rpm to 7000 then see 330 bhp , after several runs and det checking eventually ended up with 19 degrees of ignition and 383 bhp ande a stable egt so looking at a compressor map isnt god and to think you can add restrictions like shit airflow through the cooler and head then charge temps deducting ignition if to high so imo a compressor map means theres a rough ball park imo as the end results is only obtained if IF the total spec either works by luck or is correct then the person who can map a car that is spot on .
So ideally it will do what it says on the can but rarely does lol due incerficant spec or mapping
#102
Jay,
Jay,
#103
Caraholic
you see read a compressor map will idicate what a turbo can do in a correct enviroment but its not always the case
I already KNEW his c/r (he posted it), I already KNEW what turbo (he posted it), I already guessed at the ignition values they would be trying to run (late teens as per my post above ), so I just needed the boost pressure to give a guestimate of power (it was the only thing I wasn't 100% sure of ). So in effect, asking for the boost pressure being used was the final piece of the puzzle to enable a calculated guess rather than plucking a figure out of thin air .
I've seen enough of these engines to know what ignition value you're going to TRY and end up with .
Why didn't you leave it at 8 degrees if you wanted to prove a point . I think I could work out that Mark isn't as "retarded" as you .
#107
Actually Jay, what you are saying there is a nonsense.
Mike has already said (or implied) that it is a given that in Mark's case the mapping will be spot on, so I think its fair for him to assume that it wont be 100bhp down due to the wrong ignition values.
A compressor map puts you in a useful ballpark based on some other guesses, it doesnt allow Mike to do what he said which is:
As it shows airflow at that boost level over a big range, as ive already mentioned, so you cant see what it is doing, you can only see a range of what it can potentially do.
I dont believe he needs a compressor map to know that a GT3071 is vaguely in that sort of ballpark. But maybe ive been unfair and he knows so little about these turbos that he actually DOES need a compressor map just to see what ballpark its in so he can make a complete wild guess, but if thats the case, his reply was worded badly.
If I had the boost pressure, I could look at the compressor map and see what airflow it was doing at this amount of pressure to get a rough estimate of the power
#109
Sponsor
Read what I posted you nuggart .
#110
Did it tell you that a GT3071 is a comfortable as a vaguely 400-450 bhp ballpark turbo?
If so, im amazed you didnt know that already TBH!
#112
Caraholic
However, I have seen enough of these engines to know how they perform at certain airflows and the fact that Rich has listed all his ancilliaries in his resto section (quite a lot of which I actually provided ), I think I can give it a pretty accurate "guess" - we'll see tomorrow won't we ?
Does that make you happy?
#113
Sponsor
I would concede that if it was an engine I knew nothing about VE wise, then looking at the compressor map would not enable me to do anything other than give the range of power that Chip quoted.
#114
Thats my WHOLE point, that you are making out you could get useful information from the compressor map for Rich's engine, but the only way that would be true is if you had NO idea at all what sort of airflow a GT3070 is capable of, and surely you must have at least had a vague indication?
#115
Mike,
you havent provided me with any ancilleries for my engine as it was built 5 years ago before i knew this gay blond haird bloke caled Mike Rainbird existed
Just to make this easy my engine spec:
7.6:1 c/r
BD14 inlet
Standard head ports and standard exhaust cam
GT3071.82
4 x 750cc injectors
7.6:1 c/r
BD14 inlet
GT3071.82
4 x 750cc injectors
#119
Caraholic
Mike,
7.6:1 c/r
BD14 inlet
GT3071.82
4 x 750cc injectors
7.6:1 c/r
BD14 inlet
GT3071.82
4 x 750cc injectors
