3 door gearstick
Old 28-09-2008 | 09:26 AM
Harris.'s Avatar
Harris.
Default 3 door gearstick
Hi all, was putting the 3 door away last night , went from 1st gear too reverse . As it went into reverse the gearstick snapped in my hand, how easy are they to change and has anyone got one for sale
Wrong section i know but need one asap as im ment to be going to battlesbridge car show today
Old 28-09-2008 | 09:29 AM
fordrs2005's Avatar
fordrs2005
the gear selector is a 2 part , has the bolts not just come out thats under the gator ? as a had a 2wd saff once that had a vibration on the stick and it was the bolts had worked there way loose so just needed a little tighten think there 13,s
Old 28-09-2008 | 09:30 AM
Harris.'s Avatar
Harris.
No mate deffo snaped
Old 28-09-2008 | 09:37 AM
steves24V's's Avatar
steves24V's
They are easy to change or weld it up if you've got a welder handy, sorry i don't have a spare to sell ya.
Old 28-09-2008 | 10:06 AM
Harris.'s Avatar
Harris.
Got the old one one just a min ago , snapped !!!!!!!!
Does it have to be off a 3 door or are saff ones the same ??
Old 28-09-2008 | 10:13 AM
LHD220Turbo's Avatar
LHD220Turbo
all the same; very unusal for them to snap
they are in 2 parts, held together by 2 13mm bolts (i think) you better hope its snapped above the bolts then, otherwise its gearbox out!
Old 28-09-2008 | 10:15 AM
Harris.'s Avatar
Harris.
Yeas mate its snapped just above the 2 13mm bolts thank god
Old 28-09-2008 | 10:17 AM
Steve Escos's Avatar
Steve Escos
Saff ones are the same. They usually go for £15 upwards. I may have a spare if your stuck
Old 28-09-2008 | 10:23 AM
marco polo's Avatar
marco polo
speak to Steve @ A1 he has ones made up on the shelf ready to go
i wouldn't weld it because the rubber melts inside of the stick it's wank after that
marco
Old 28-09-2008 | 10:24 AM
LHD220Turbo
lucky then!, easiest way to do it is remove the outer gater and them make a small incision in the rubber inner sleave (just enough to get a socket on the bolts). Saves having to take the whole lot apart cos it nevers goes back together properly
Old 28-09-2008 | 10:35 AM
Mark 3D's Avatar
Mark 3D
Moderator
Ive got one but Im in Burgess Hill :-(
Old 28-09-2008 | 10:44 AM
Harris.'s Avatar
Harris.
marco
No mate im not going to weld it, thanks for all the offer's, if i dont come across one at this car show i will have one off someone of here
Old 28-09-2008 | 10:52 AM
Mark 3D's Avatar
Mark 3D
Moderator
Not sure thats correct as I changed mine for a B&M quickshift and that didnt involve taking the gear box out!?
Old 28-09-2008 | 02:43 PM
Harris.'s Avatar
Harris.
No luck at this car meet , so who has one for sale
Old 28-09-2008 | 02:44 PM
Easily done with gearbox in car, though you will have to take off the support so you can drop the box at back end a bit, then four bolts around edge of metal plate hold selector lever in.
The way to cure vibration on solid ones is to use something like a truck wrist pin welded around the lever shaft, it changes the resosnat frequency above that which the box vibrates at and stops it as the vibes don't contain enough energy to overcome mass of the heavy wrist pin.
Old 28-09-2008 | 03:54 PM
LHD220Turbo
no, probably not; but you'd have to drop the arse end of the box, complete arse ache if you ask me, just for a gear lever!
Old 28-09-2008 | 04:02 PM
STUCOS's Avatar
STUCOS
Comon fault,2wd sticks breaking,dont see them for £15 any more,more like £50,collect as many as i can for spares
cheeRS stu
Old 28-09-2008 | 05:22 PM
Harris.'s Avatar
Harris.
Im sure i will find one for less than £50
chowfornow
14
05-01-2019 10:01 PM
07-10-2015 01:56 PM
mpilk
27-09-2015 10:21 AM
Vacuman
22-09-2015 01:09 PM
Vincereese
18-09-2015 01:48 PM
