T4 conversion help needed
Old Sep 21, 2008 | 05:51 PM
BRAMMER's Avatar
BRAMMER
Default T4 conversion help needed
T4 owners or people in the know
I may be fitting a T4 to my 3dr which is currently running a T34 .48, 803's, MSD evo chip, 500 cooler & 2k rebuilt standard 205 engine.
By fitting greys and the T4 and another set-up at MSD would the whole package work or does it really need to be low comp??
Cams can be fitted and head work to grp A spec isn't a problem either.
Any info would be great
Old Sep 21, 2008 | 06:00 PM
col cos1's Avatar
col cos1
your spec will be fine,although i ran greys before and maxed them quiet easily,get siemens same price
Old Sep 21, 2008 | 06:09 PM
BRAMMER's Avatar
BRAMMER
Great Col i think MSD sell siemens.
Will the head gasket be fine at this spec it's a YB Grp A item.
Old Sep 21, 2008 | 06:19 PM
Gary F's Avatar
Gary F
You'll be fine mate, MSD done the same set up on my car
Old Sep 21, 2008 | 06:23 PM
BRAMMER's Avatar
BRAMMER
Excellent Gary
Old Sep 21, 2008 | 06:28 PM
col cos1's Avatar
col cos1
id say so mate,i wouldnt do a head gasket unless it went
my old saph was stage 3 +nos and on standard gasket and never went
Old Sep 21, 2008 | 06:29 PM
LHD220Turbo's Avatar
LHD220Turbo
isnt low comp old school know?
but yeah, def get siemens blacks, get them from the US, half the price
http://www.fiveomotorsport.com/
Old Sep 21, 2008 | 06:30 PM
col cos1's Avatar
col cos1
matt lewis does siemens at great prices,thats where i bought mine
msd will see you alright aswell
mind and rewire your fuel pump though as stu wont run your car up if its not getting 12-14v at the pump
Old Sep 21, 2008 | 06:31 PM
col cos1's Avatar
col cos1
mine is low comp and works well but a bit shit at low revs due to this and the cams
Old Sep 21, 2008 | 06:40 PM
LHD220Turbo
yeah not knocking it; just thought that low comp engines drive really bad off boost?
i was under the impression the latest way to get more power/torque was high comp? i'm probably wrong tho
Old Sep 21, 2008 | 06:53 PM
col cos1's Avatar
col cos1
think most tuners advise higher comp now
Old Sep 21, 2008 | 06:59 PM
dom123's Avatar
dom123
i think your need big head ports to make good power you might get stuck at t38 power instead of t4 i might be wrong.
Old Sep 21, 2008 | 07:19 PM
col cos1's Avatar
col cos1
400bhp on standard head id say
Old Sep 21, 2008 | 07:40 PM
Staffi's Avatar
Staffi
And me........
Old Sep 21, 2008 | 07:57 PM
LHD220Turbo
Originally Posted by Staffi
And me........
i'm led to believe 420 is about the limit of a standard head.
Old Sep 21, 2008 | 08:02 PM
JoeRS22's Avatar
JoeRS22
on standard comp i would whack the siemens on and keep standard cams and source a t34 .55 exhaust best of both worlds power and minimal lag..
Old Sep 21, 2008 | 08:19 PM
LHD220Turbo
i had this exact spec on mine (until i sold it), made for a very quick road car
go for the siemens and get the 83lb ones to future proof yourself, they are the same price
Old Sep 21, 2008 | 08:20 PM
JoeRS22's Avatar
JoeRS22
brilliant spec for road and having a giggle!
Old Sep 22, 2008 | 05:52 AM
BRAMMER's Avatar
BRAMMER
From the site listed above this is the info given for the 83lb is it correct
2.8 Ohms Low Impedance
83lbs/hr - 865cc/min
P/N 3105
Siemens Deka
Or
12.0 Ohms High Impedance
55lbs/hr - 575cc/min
P/N 3172
Siemens Deka
Old Sep 22, 2008 | 05:58 AM
Gary F's Avatar
Gary F
The heads limit is around 420bhp
Mines still on standard cams
And I think im using 83lbs Siemans
Old Sep 22, 2008 | 06:33 AM
You can make more power than 420 on a std head, the point is though you will reach a point where gains will be getting smaller and smaller for more more and more boost.
I always balance cost versus performance gain, no pint in a modded £1K head for extra 20bhp for example if a slight boost tweak will do it.
Always keep the cr as high as you can get away with, if injectors are near limit rail pressure can be increased, some cars(porsche etc) are 5 bar as std, with vac on, so 5.7/8 with vac off.
Proper mapping will be mind blowing driveability wise, and extra advance lower down will lose a lot of the lag, not all obviously.
Old Sep 22, 2008 | 06:41 AM
rsnissan's Avatar
rsnissan
How much more can you make on a standard head then?
Old Sep 22, 2008 | 07:17 AM
LHD220Turbo
P/N 3105
Siemens Deka
Or
P/N 3172
Siemens Deka
i think they come in 3 forms, 55lbs, 72lbs or 83lbs, i'm pretty sure they are all the same price - you will need low impedance 2.8ohms
i had the 55lbs format and the part number was Siemens Deka 3102.
i can't get onto that webiste at work for some reason, but i'm 99.9% confident these are the ones you need
P/N 3105
Siemens Deka
JoeyBoyden
Jan 4, 2024 02:36 PM
borboyous
Aug 22, 2015 11:17 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
col93saphcos
Aug 7, 2015 03:21 PM
