boost hoses,
Old Nov 10, 2004 | 12:00 PM
sf's Avatar
sf
Default boost hoses,
when using the amal valve in a s2, where does the turbo hose and act hose go to in the amal valve,top and middle? does it matter if they go in the wrong one?
and also can u use a bleed valve in the hose going to the amal valve from the actuator to control the boost
Old Nov 10, 2004 | 12:49 PM
Bomber's Avatar
Bomber
C to turbo housing
W to the actuator
R to the airbox
I wouldnt plumb them up wrongly!
I don't run a bleed valve so you'll have to BTTT this thread to get someone else to answer - but imho - you should just get a -31 actuator and new chip rather than 'fooling' the ECU with a bleedvalve.
Old Nov 10, 2004 | 01:11 PM
CabrioTurbo's Avatar
CabrioTurbo
if you plumb it up wrongly it will supply limitless (until the engine blows anyway ) boost!
i dont know what would happen if you put a bleed valve in line with the amal valve but i imagine it would mess it up cos the amal valve works in a sort of backward way
Lemon S2's Avatar
Lemon S2
you can put a bleed vavle there yes but imo I wouldn't bother. When I had one on mine it did really seem to do anything & it run like a pile of shite.
Old Nov 10, 2004 | 02:39 PM
sf's Avatar
sf
Originally Posted by Bomber
C to turbo housing
W to the actuator
R to the airbox
but how can i run about 20 psi with out the bleed valve? is it just a case of screwing the actuator shorter?
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
