no goldmember :) whats my engine worth complete ?
just curious what my engine is worth complete. turbo reciept £1300, block,rings, headgasket,sensors and gaskets,water pump,cambelt,actuator,air filter,clutch,oil pick up,oil pump spring etc, mocal oil cooler £2700 so thats receipts for 4k also has stuff but no receipts big wing sump, siemens 870cc, coilpack conversion, level 8 pectel board live mapped by msd bill was £700 all in. so receipts for about 5 k and head is 4k miles double springs, bd14s, bronze guides new tapets. for the whole engine with turbo and new loom, sump, inlet and ecu. is it worth 5k for the lot ?
so why dont you put his box and engine in yours and sell his shell and other parts !! and if there is and cheap compomotives in there
peak power about 100 hp down but mid range is big difference. my car is ideal for standard drivetrain and more torque or power and would become unreliable. my mind is made up always wanted euans car and said to myself if he ever sells il buy it for the right money.
I'm guessing your car is rather tidy and Euans although good condition for its age is unlikely to look as nice so I would swap your engine into his and sell it back off that way.
You are essentially just buying a normal Saph with a powerful engine, the gearbox isn't that much to purchase and it still runs a stock diff, its a bargain at 10k but with what you already have I'd be more inclined to just build one to a similar spec after you have sold off your T4 and the other bits.
Either way it sounds like there is another seriously rapid white Saph coming to town
Snap................
I'd for the money you'd spend buying Euans car, you could have yours to the same spec.
Don't want to put the mockers on a sale though, so I'll keep my mouth shut.
Ooooooooops, too late, I've already said it.
Just looking back here mate and what i said sounds bad. I just meant that you seem to have your saff just the way you like it and it seems pretty immaculate from your pictures.
Rather than change euans car to the way you like it i thought it would be easier to swap engines.
Good luck mate anyway. His/your car is an absolute weapon!
