Firing orders and big bang... discuss
I've been reading a few old bike magazine articles and there was something about 'big bang' on a yamaha? Think its where 2 cylinders fire at once (central pair) then the other 2 (outer pair). There wasnt much info on it, and I was wondering if anyone knows anything about it? Are there advantages/disadvantages?
Alex, that article explains it very well, its about loading and unloading the tyre with spaced out 'pulses' of power, rather than a smooth band.
Its very good, check me out educating people. I wish
I'm not sure. Totally see your point, I was thinking the same, but it was on about how the newer tyres let go in a very sudden manner and it gives the tyre time to recover between pulses, and the rider can feel more of the action. The bit at the end about radios made it click for me
Mike, say I wanted to try this (i'm not going to, just fascinated really) would it be a case of having cams made up to pair up the cylinders, and altering the firing order?
Inertia torque is noisy, and thus interferes with the rider's ability to tune in a good signal. Enter the big banger, which reduces the periods of inertia torque by compressing the firing pattern. As the crankshaft is absorbing inertia and kinetic energy from the pistons and connecting rods, it's doing so in a smaller window of its revolution. The result is a longer period of each revolution that is noise free, or relatively so, giving the rider a stronger signal between the throttle and the rear tire.
Every revoultion of the engine 2 cylinders will fire together.
Thats 200 BIG bangs per second - or 1 bang every 0.005 secs = 5mS intervals.
How the does he think a rider can feel that?
Alex
On a motorbike engine your dealing with much lighter components so there are much reduced forces - but the same disadvantages remain.
Alex
Fair comment, but would it not be 100 bangs per second as its a 4 stroke? Either way, you would have twice the frequency if it were a screamer would you not?
*** Sierra RS Custard ***
You dont gain torque on average through the cycle, so would see no change on any dyno graph (as it is a smooth curve, it doesnt show your torque rising and falling during individual strokes of the engine anyway.
very bad idea IMHO, especially as you will need a massive exhaust housing to allow the gasses out all at once from 2 cylinders.
Rossi's yamaha moto GP bike has run big bang for the last 4 years.
Its something to do with being able to feel/find the limit between grip and spin better.
So yes, moto GP riders can feel the difference.
Had discussions on other forums about the subject before and came to the conclusion that most of the articles written are bollox BUT there must be somthing else that I'm not considereing as it makes the bikes faster.
Alex
Nah thats ok mate - I double checked it before I wrote it down thats all...
Alex
Alex
One thing it may explain is why we have seen a rise in bike powersliding in recent years. If they do have more control and feel, they are able to approach limits more easily.
Caraholic
Steve,
Buy the November issue of Performance Bikes, as Yamaha have just productionised a "big bang" engine (well a "long bang" one, with a staggered crank and a 270, 180, 90 then 180 firing order ) in the form of the latest R1 . There are details in there on how this works .
For those that are interested they are saying that the reason for the increased grip is that at 100-120mph and with just a 180° firing order, there is a power pulse every 10cm of travel, whereas a big bang has 20cm. This means there is more time for the tyre to recover grip in between power pulses .
with regards to traction is it better to have one big hit on the rear tyre or lots of little ones?? either way would you gain more traction by running a 12 cylinder engine rather than a four if the tourque/hp was the same, as there would be 3 times the pushes??
i was thinkin it would be better to do lloads of little taps rather than one big hit (for want of a better way of explaining it) as there would be less force on the tyre at anyone time but the same force on it over one stroke, yamaha must no something we dont lol
Maybe they could spring load the rear sprocket on a really strong spring, so that it takes some of the shockload during the hits too to further smooth the pulse?
Must be some reason that does work though, or they would have done it, lol
I guess ultimately they want as much time as possible with NO load on the tyre, and everything me and you are suggesting actually makes that worse not better, we're focussing too much on what happens during the load, and not in between them.
i understand what the big bang engine is but fail to see how it can be better but anyway, what is an ever-firing screamer engine?
how does that work?
how does that work?
SMILER258
28-09-2015 09:04 AM
