What is considered low oil and fuel pressure?
Old 18-09-2008, 07:13 PM
Diablo
Diablo's Avatar
Default What is considered low oil and fuel pressure?
Gents,
I am ordering some oil and fuel pressure warning lights and have a choice of sensors. For a 400 BHP YB, at what pressures should the sensors be triggered?
Thanks in advance.
Old 18-09-2008, 07:52 PM
LHD220Turbo
LHD220Turbo's Avatar
Originally Posted by Diablo
Gents,
Thanks in advance.
the standard cossie oil light on the dash come on at 7psi i believe, but that´s more of a "your engine is fucked" light rather than a warning light
oil pressure depends on what oil & pump you are using and the age of the engine
also oil pressure is affected by how hot or cold oil is, and if the engine is at idle or not
not exactly sure on fuel pressure so cannot comment
Old 18-09-2008, 07:55 PM
LHD220Turbo
also, go for a mechanical oil pressure gauge and make sure the sender is the same make as the gauge itself as they have different resistance if mixed and matched...(i found this out to my cost )
Matt
Old 18-09-2008, 08:05 PM
Diablo
Diablo's Avatar
Many thanks. The engine is around 15K old and has a standard oil pump. My main concern is to protect the engine when the oil is warm, i.e. on track
Old 18-09-2008, 08:19 PM
LHD220Turbo
it really depends on what oil you run?
i recomend you use 10-50 pro s Silkolene, its pricey but a very very good oil. contact Oil Man off here and you´ll get a discount if you mention Passion Ford
if you are tracking the car you need to be careful of oil temp. it maybe worth fitting a oil cooler if the track is the intended use
mickparky81
Ford Focus ST
30-08-2015 06:58 PM
Prickly_buzz
25-08-2015 11:33 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
ekjim
17-08-2015 08:57 PM
Zoggon
10-08-2015 10:39 AM
Quick Reply: What is considered low oil and fuel pressure?
