Few Cosworth YB questions
Old 18-09-2008, 11:32 AM
Oranoco
Oranoco's Avatar
Default Few Cosworth YB questions
What is a factory standard bottom end good for power wise?
What is the weak link in the engine when tuning?
What will a stock head flow to?
What level would you change rods and pistons for tougher items?
What cost to achieve a genuine 400bhp?
What can a standard turbo deliver?
Old 18-09-2008, 11:38 AM
Gordon1
Gordon1's Avatar
are you talking 2wd or 4wd and how old is the std engine
Old 18-09-2008, 01:41 PM
The Youth.
The Youth.'s Avatar
Answers
1 500 ish
2, money!!
3 400 ish
4 pistons when or if going for compression change
5 blues or greys, chip, actuator, good fuel supply, cost wise dunno
6 t3 2wd +4x4 320 max, t34 escort cos 400 if fitted with 360 thrust bearing
steve
Old 18-09-2008, 03:00 PM
LHD220Turbo
LHD220Turbo's Avatar
assuming 2wd standard
crank = never heard of one failing
rod & pistons = 500hp
head = 420hp
t3 = 320hp ish
block will need changing from a 205 to a non turkish 99 200 block between 450-500hp, that is the weak link
above assuming the engine & turbo is in good condition to begin with, so i would say a standard bottom end is good for 450hp ish
although opinions differ, i´d want to change the head gasket
cost depends on what you can do yourself, new or second hand parts?
Anutternutter
24
31-08-2015 01:24 PM
blackbeautyzetec
29-08-2015 02:11 PM
Caddyshack
19-08-2015 07:29 PM
cossie4x4
14-08-2015 06:29 PM
14-08-2015 07:29 AM
Quick Reply: Few Cosworth YB questions
