Small scale plastic mouldings!
Im trying to have some badges remade. They have a clear injection moulded plastic layer on top of the vynal substrate lettering. The gel type badges are no-where near thick enough.
Im looking to get the plastic bits made but not sure how to go about it. the plastic bits only 3cm by 2cm and 5mm thick but its essential to the originality of the badge im making. The substrate vynal lettering i can get done easily and relatively cheaply but the plastic moulding i have no clue about.
From what i understand for most plastic injection moulding is expensive to set up the metal mould (in £000's ??) but the finished product can be made cheaply once the set up costs are done.
Now i dont want to spend thousands. (i dont have it!! ) I know you can make resin moulds quite easy but can resin be made in clear and poured bubble free???
Alternatively is there any DIY way of doing low volume plastics moulding at home likely to produce good results??? I dont mind it taking lots of time.
Plus does anyone in the "know" have approx prices to set up such a small mould and produce 1000 units???
If its only 1000 not many companies would be interested.
Mould itself wouldnt be single impression, it would probably be 8 to 16 impression.
Its been a while since I have been in a plant, but worked for a plastics packaging company for 11 years so bit rusty on pricing lol
We used to make bottles and caps (Ambre Solaire, Matey, Soltan, brylcreem etc) but for 1000 caps for a ambre solaire bottle would be around £30/1000.
Tooling costs were in the region of £30k for a 16 impression tool.
no idea on home production.
Well,
I have contacted a local vacuum moulding company near me about a similar low volume custom thing and its more likely to be a hundred or so pounds to make a mould from a buck we give them, although in fairness this is to form something slightly larger and out of thinner material than you are talking about. But it may be worth a flick through your Yellow Pages and having a few chats with people, the worst they can say is No !!
J.
J.
07-10-2015 12:56 PM
