some advice needed please on turbo
hi people i was getting a leak on the banjo fittings for the water from header tank ,so put new copper washers stil was leaking so tightend the banjo bolts abit more and snap one bolt ,so got new ones new washers and tightend again and it stil leaks .the engine can be running and there no problem but when u rev it abit when the engine come back down in revs it seem to leak abit i guess it coming from the banjo fittings but dont want to tightend more case i break it again any ideas have i missed something out
![Talking](https://passionford.com/forum/images/icons/icon10.gif)
the banjo fitting smetimes crack on the brazing joint mate quite a common problem you dont need to really hang off the pins to get the copper washers to seal as they are so soft that is y they use them have a close look at the point where the pipe enters the round part of the banjo fitting hope this helps regards sie
big_Rad
15-09-2017 09:36 AM
