c/r difference in 2wd and 4x4 yb head and how tell the difference ?
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
i didnt even know that the head made a differance to comp, there are a few other differances in the heads but as above the turbo damper mount is the easiest way to tell
im not sure thought i remembered someone saying 4x4 head gives lower comp ? maybe its pistons then ?
2wd pistons/4x4 head increases comp by about .3
4x4 pistons/2wd head lowers comp by about .3
thanks martin. my pistons are 4x4 according to paperwork and supposedly 7.5 with pocketed 4x4s and 2wd head. so in theory a 4x4 head will put me at 7.8 c/r. do i dare ?
sounds to me more like your actualy running 7.2-1 if your using a 2wd head, if its 4x4 pistons they'll be meant for a 4x4 head so if you put the 4x4 head on it'll take you to the 7.5-1 that you thought you were at already
If the engine was built correctly and CC'd it will be 7.5:1 like is written on his paperwork.
thanks mate. if thats the case il try gettin the 4x4 head thats been done.
Tbh mate as the heads coming off anyway why not CC the engine so you know the comp for sure? With the power you are going for i wouldnt take anything for granted as it will end up costing you alot more money/time.
