saph 4x4 front brakes ????????
whats the minimum disc thickness for a 4x4 saph front disc ?
also saph with bigger discs but oe callipers can you tell the difference over standard setup ?
thanks...........matt
if you want bigger discs, you could better buy big calipers also. because a big disc kit will make the OE caliper to hot in short time.
whats your brake setup now?
lol loved them just cant justify spending 1k + on some front brakes
setup at the moment is x drilled and grooved discs front and back
what happens when the calliper heats up ? does it just boil the fluid ?
will it be bad even when the discs are just a little bit bigger ?
the big disc kit is not a real good option with 4wd calipers. the calipers are to small. the 2wd caliper is much better but wont fit. correct if im wrong.
buy a 4pot 330 kit and you wont regret(spelling) it.
frofl but thats 1k plus !!!!
anyone want to give me 500 quid so i can buy the proper kit lol
im sure it wont be done next year then lol
will be fun slowing car down at croft with stage 3 power on standard sized discs lol
im sure the bigger discs option is ok for now ie temp fix sort of thing till i can save more up
cheers guys............matt
ok another question
will the calipers heat up for naormal road driving or just on track ?
surely they could take a 15 min track session at croft and be ok ?
