zvh what turbo?
just bought my first erst a nice black s2 (pic in other post) and me not knowing much about them a mechanic friend tells me it has a zvh conversion (dipstick at the front) done and what i was wanting to know was
1)can i put a cosworth t34 (think thats it) on it
2)how do i tell if its a 1.8 or a 2.0
3)what cambelt do they use cvh or ?
i did try the search function but could`nt find what i was looking for.
thanks in advance
thanks in advance
Colossal Pervert
The engine size is cast into the front of the block in big letters (most likely behind your turbo)..
Yes, you can put a T34 on it.. you can put any turbo you like on it!
1)can i put a cosworth t34 (think thats it) on it.......... yeah no problems there go with the 0.48 exhaust, i run a 0.63 its a bit too laggy.
2)how do i tell if its a 1.8 or a 2.0......... the 2.0L has 2.0 on the side of the block.
3)what cambelt do they use cvh or ?........... use the standard cvh cambelt
thanks in advance![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
thanks in advance
thanks
sean
as for the cambelt, cvh belt tensioner will fit, i think you need a plate for the tensioner though? go on burtonpower.com and they will have everything you need.
thanks for the info guy`s as for the spec all i have paperwork for is power engineering cam and adjustable pulley some head work and stage 1 t3 ? it does`nt say efi on the inlet so i presume its mfi.
cheers.
cheers.
JK12
33
26-04-2021 12:09 PM
