whats larger throttle bodie choices are there for 2wd
Caraholic
If you have no choice in changing because of clearance reasons, then we do a slimline version that is bigger than standard (designed to go with the Swedish plenums when fitted in Escorts), but if you have no such issues, then there is really no point in changing at your anticipated power level.
I think it is funny that people pay a fortune for 60mm eec TBs when you can unbolt a 60mm one from any 2ltr zetec in a scrappy for a fiver.
I have also used 535 BMW ones in the past which are 65/67 from memory. and are easy to fit and convert to other TPS.
MAD Carbon Cossie
I've got an EECIV throttle body on my Swedish plenium & had to space it away from the plenium as the throttle linkage fouled. I also had to make up an adaptor to fit the Weber TPS & make up a plate to cover the Idle Control Valve as I didn't have one !!
I now got an ISCV from B9COS Thank you very much !!
jb
jb
Caraholic
So you have to be careful about picking a suitable TB that won't leak or have the throttle butterfly jamming, due to it being made out of the wrong material, so expands with the heat of the charge air and fouls the throttle body and potentially jamming open or closed - something many DIY'ers forget....
Coincidentally, the slim-line / larger version that I sell, addresses these issues .
http://www.randbmotorsport.co.uk/sho...?ProductID=273
You are right Mike, sealing was an issue i was concerned about too.
A n/a TB will only ever see vacum so i was concerned how their seals would cope with positive pressure.
However having tested them with a compressor and some soapy water i'm happy both the ones above will hold 2 bar.
Most of the 535 bodies used are 20ish years old now so always worth checking for leaks.
It is an interesting point you make about expanding butterflies jamming Mike.
My point of view on that is that the OE manufacurer will have looked at thermal expansion coeffecient of the butterfly material and allowed enough room for it to expand upto at least 100 deg as this is what the engine runs at and in theory the TB may nearly reach this through heatsoak via the manifold.
The last thing a manufacturer would want is a throttle sticking open so i expect them to be working to a very big safety factor in this area.
Hopefully your turbo air charge will never exceed say 60 deg so you should be well within the temp limits of the TB design.
*** Sierra RS Custard ***
I agree, and I bet most people's 20 year old cosworth ones leak slightly by now too, so Im not sure Mikes tests of "old" throttle bodies really prove a lot!
The seals are designed on a N/A TB to resist a pressure differential of as much as about 12 psi anyway as standard, and are always over engineered.
I was once told by an automotive design engineer i was chatting to that pretty much every thing on a car is designed with a safety factor of at least 5.
Eg the suspension will take 5 times the design loads before breaking.
I expect they apply this sort of factor to any other critical parts.
It occured to me the other day, I don't enjoy working on cars anymore, just get bored of getting dirty, cold and cut to bits . Just want to drive the fucking things
Engine Machinist
