My WRC Escort Zetec/Cosworth Build
Old 08-07-2008, 08:32 PM
  #161
RUBY123
RUBY123's Avatar
cool project should be proper when finished ruffly how much would it cost for the machine work for the main caps thanks a lot
Old 08-07-2008, 09:02 PM
  #162
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
not a clue, as it didn't cost me a penny! Do you have some that you need fitting then? Where abouts in the world are you?
Old 08-07-2008, 10:11 PM
  #163
RUBY123
RUBY123's Avatar
Well im in birmingham and im thinking of geting some ive got a cgi block and for a few extra £ it would be silly not to
Old 08-07-2008, 10:31 PM
  #164
Turbo Zetec
Engine Machinist
well if you're prepared to come to me, i'm sure we can sort a deal out
Old 08-07-2008, 10:50 PM
  #165
RUBY123
RUBY123's Avatar
pm on its way
Old 08-07-2008, 11:27 PM
  #166
rigwrecker
rigwrecker's Avatar
i like the look off this project it will surprise alot off people when done im sure
Old 08-07-2008, 11:33 PM
  #167
Turbo Zetec
Engine Machinist
i hope so, its what i'm aiming to do
Old 11-07-2008, 04:50 PM
  #168
Turbo Zetec
Engine Machinist
quick update, i went into work early today...
first job was to get my head on the serdi (seat cutting machine). i decided to de-shroud the area around the valves to allow for more air flow. i also topped the seats down my 0.5mm to get some more volume in the chamber:
the next job was to cut the throat out of the seat to help with my porting. here's a pic of it done, notice the 45 degree seat hasn't been machined yet, just incase i slip with the die grinder :
here's a pic of one chamber completely de-shrouded and with all throats cut
thats all for now!
Old 18-07-2008, 12:34 AM
  #169
Turbo Zetec
Engine Machinist
Time for another update!
I’ve been hard at work once again! This time, I’ve managed to do a mock build of my engine to CC the area above the piston… which was hardly worth it as it was only sitting 5 thou below the block face when at tdc!
a pic of the crank in:
Then we decided to lower the height of the pistons to the depth of the bowl, as it was only just over 1mm deep.
Before and after:
After this was done, we cc’d it again, it turned out at about 10cc above the piston… this means that currently with the unmodified heads, the black top will make 8.98:1 and the silver top will make 8.5:1. I’d really like to use the black top head, as it uses solid lifters as standard, but it will need a lot to come out of it to match the silver top one, let alone better it!
I may try modifying one BT chamber tomorrow, to see what numbers I can make. I’ve managed to pick up another whole engine for ~£40, so if I screw it up, I’ve still got a spare!
here are some random pics of the blacktop block from all angles... notice it only has one core plug
thats all for now, hopefully more tomorrow!
Old 18-07-2008, 08:38 AM
  #170
Ryan
Ryan's Avatar
awesome mate.
would love the facilitys to do this by myself, would be tinkering all day
Old 18-07-2008, 12:43 PM
  #171
woolford
woolford's Avatar
Originally Posted by Ryan
awesome mate.
second that
Old 23-07-2008, 11:21 PM
  #172
Turbo Zetec
Engine Machinist
unfortunately my boss makes me work for him in the day... which is very inconsiderate of him . i tinker when i get the chance though, either lunch times or after work.
the good news is that i can now build the bottom end, as i have all of the necessary parts . My ACL bearings arrived this week and my billet geared oil pump is on its way from Will @ MSD .
All i need to do is to balance the crank and front pulley, then it's pretty much ready to be built!
i've started to modify the combustion chamber to try for some more volume, but i haven't re-measured it yet, so can't tell if its made the difference i needed. i've also spoken to cometic about making a 2mm head gasket, which will help considerably
Old 24-07-2008, 12:30 PM
  #173
NEWTON
NEWTON's Avatar
brilliant work mate
Old 25-07-2008, 02:12 PM
  #174
JonnyBravo
JonnyBravo's Avatar
Good work mate, I have the end cap you require and I'll bring it to TOTB so I'll give it to Andy
Old 04-08-2008, 08:56 PM
  #175
steves24V's
steves24V's's Avatar
You have been a busy boy martin haven't been on here to see how you've been getting on with it for ages,
It look's like you've been getting some really good comments aswell
Old 16-08-2008, 12:10 AM
  #176
Turbo Zetec
Engine Machinist
It's about time for another update!
i've been majorly busy this week... where to start? ah yes, the block!
ARP's fitted:
bearings fitted and crank laid in (note bearings are covered in graphogen):
and a view from underneath of it all in place:
i also refitted my bore jets:
and got my pistons and rods fitted after a while gapping the rings :
now for the head... i've been playing around with the die grinder in my shed and i came up with this:
it dosen't look the prettiest, but thats mostly because it's covered in shite
now... i've been looking into double valve springs lately (mainly because there is likely to be an extra 30lb of pressure on the back of the valves when closed), but they're a shite load of money because of the work involved
i'm going to have a crack at making my own instead here are my new guides modified to take vauxhall stem seals:
here's what the originals look like:
fitted into the head:
when fitting new guides, the valve often dosen't seat as it should, so they all require cutting again (which needed doing anyway), so i managed 4 angles on all of the seats:
thats all for now, i'm pretty pleased with what i've got done so far
Old 16-08-2008, 01:24 AM
  #177
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
Looks shit hot mate!
I liked the picture you sent me by text the other day
Old 16-08-2008, 03:27 PM
  #178
Turbo Zetec
Engine Machinist
cheers will
what pic did i send you? i have a bad memory
Old 16-08-2008, 10:02 PM
  #179
Dan
Dan's Avatar
Cracking work! Looks fantastic mate!
Old 16-08-2008, 10:09 PM
  #180
rst-g
ZETEC TURBO
rst-g's Avatar
need more pics!!!!!
Old 21-01-2010, 04:26 PM
  #181
Turbo Zetec
Engine Machinist
This project is now for sale - the shell is on ebay and the rest of the parts will be listed in the for sale section very soon!
Old 21-01-2010, 05:38 PM
  #182
steves24V's
nnnnnnnnnnnnnoooooooooo, what are you doing??????? if only i had the cash.
Old 22-01-2010, 09:41 AM
  #183
AustenW
AustenW's Avatar
Nice Work, should do some good numbers on that spec
Old 22-01-2010, 05:00 PM
  #184
Received 1,044 Likes on 998 Posts
looks well mate.
Old 22-01-2010, 11:24 PM
  #185
tezmanian devil
tezmanian devil's Avatar
engine work look's ace mate, im using a blacktop zetec turbo for my project, the guy that built my engine only got the cr down to 8:9:1 though
cant beleive your selling up though, you should keep it!!!
Old 24-01-2010, 07:37 PM
  #186
Turbo Zetec
Engine Machinist
i'm being sensible unfortunately and i believe congratulations are in order daddy steve! destined to be skint forever!
cheers for the support everyone, but it needs to go. i'll probably have another in the future though
Old 25-01-2010, 09:07 AM
  #187
steves24V's
Thanks mate does this mean that i can have my gearbox back lol, Im pretty sure i'll sell the sierra this year too, keep trying to get it sorted to sell but then want to keep it.
Old 25-01-2010, 03:35 PM
  #188
Turbo Zetec
Engine Machinist
haha, you should donate it to me! haha, i'd make good use of it! i'm sure you can have your box back too - how about i swap it for the sierra? haha.
Old 01-02-2010, 05:58 PM
  #189
Turbo Zetec
Engine Machinist
more parts for sale in the appropriate section
Old 02-02-2010, 09:20 AM
  #190
Zzz...Zzz
Zzz...Zzz's Avatar
Looks good! Thumbs up for choosing the zetec way, I think it was a wise decision.
Old 19-09-2010, 08:22 PM
  #191
Turbo Zetec
Engine Machinist
Right, i'm back in business! I've managed to keep the car for now, so am going to build it on a budget... a very tight one! Unfortunately most of my good bits went on ebay to pay the bills, so i'm going to have to source alot of new bits and skimp in areas that i wouldn't have before.
first up is the engine - it's been sold! so in its place, i'll be using another zetec with some vauxhall pistons. i may try for a t28 or t3 setup at first to reach 300ish hp.
the awesome brakes have also gone! but lady luck stepped in this week and gave me some free 4x4 cossie calipers they'll be fine for my first engines power!
the AVO's will probabably go on ebay, to be replaced by some Koni's (not sure if i'll use 2wd or 4wd suspension yet).
basically i'm going to try to build a nice neat, but different 'escos'
Old 19-09-2010, 08:40 PM
  #192
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
glad to see your cracking back on fella,
just out of curisoity ,
how much would you charge to rebuild a yb head , its been stiripped bare for porting , ive got new guides , my valves ,seals , just waiting on valve springs ,
so basically , a super fine skim , fit guides , ream/ check valves and seats , assemble springs caps ect ,
can do the assembly meself , but never done guides before , want to make sure there seated a1
drop me a pm if you dont mind mart,
beef
Vincereese
01-06-2023 09:14 AM
JK12
33
26-04-2021 12:09 PM
FlashRS
14-09-2015 12:36 PM
Vincereese
18-08-2015 03:57 PM
allye
Alloy wheels and ICE for sale
11-08-2015 09:49 PM
Quick Reply: My WRC Escort Zetec/Cosworth Build
